I have a jetson Orin AGX and we’re expecting to use pin 85 on the camera connector (J509) as a 1.8V IO pin. On page 25 of the carrier spec (SP-10900-001_v1.2) it notes that pin as having a 1.8V level. When we measure it, however, we’re seeing 3.3V. Why is that? Looking at the carrier schematics, it looks like it’s a pass-through from J3 pin A62 to J509 pin 85.
I found a related NVIDIA discussion that may help explain the behavior:
I would recommend checking the AGX Orin pinmux spreadsheet to identify which I/O voltage block GPIO10 (A62) belongs to and verify the configured I/O Block Voltage for that block.
