Jetson Orin AGX : Lag with some desktop environments
Hello everybody,
If I install on my Jetson Orin AGX the desktop environment openbox or LXDE or fluxbox, I have a screen lag of one to two seconds (when I write with the keyboard, when I click with the mouse , and especially when I move windows).
I don’t have this issue with XFCE or Gnome.
It’s very disturbing.
Do you have an idea to solve this issue ?
Ludo
Hello @ludo64000
This is due the nvidia-display-driver.
Could you please share logs ?
Please execute $ sudo nvpmodel -m 0 and sudo jetson_clocks, and try again. To check if there is improvement in maximum performance mode.
Hi @ilies.chergui and @DaneLLL,
Unfortunately the issue is still present even after running the commands nvpmodel -m 0 and sudo jetson_clocks.
The logs are attached.
installed_packages.txt (228.7 KB)
lsmod.txt (3.3 KB)
syslog (230.1 KB)
Xorg.0.log (19.4 KB)
Anyone to help me on this ?
You may check GPU loading in the condition. See if GPU is at full loading and triggers the issue. Please execute sudo tegrastats
@DaneLLL thanks for your reply.
Below is the result of the command “sudo tegrastats” when i move a window with openbox with the lag (i think the GPU is not fully loaded) :
09-14-2022 09:27:31 RAM 914/30536MB (lfb 7177x4MB) SWAP 0/15268MB (cached 0MB) CPU [0%@729,6%@729,0%@729,11%@729,0%@729,0%@729,0%@729,0%@729,off,off,off,off] EMC_FREQ 1%@665 GR3D_FREQ 25%@305 GR3D2_FREQ 25%@0 NVJPG1 729 VIC_FREQ 115 APE 233 CV0@-256C CPU@47.593C Tboard@36C SOC2@45.093C Tdiode@37.5C SOC0@44.5C CV1@-256C GPU@43.437C tj@47.593C SOC1@45.062C CV2@-256C VDD_GPU_SOC 3184mW/3184mW VDD_CPU_CV 796mW/796mW VIN_SYS_5V0 4327mW/4327mW NC 0mW/0mW VDDQ_VDD2_1V8AO 704mW/704mW NC 0mW/0mW
09-14-2022 09:27:32 RAM 914/30536MB (lfb 7177x4MB) SWAP 0/15268MB (cached 0MB) CPU [4%@729,8%@729,0%@729,29%@729,0%@729,0%@729,0%@729,0%@729,off,off,off,off] EMC_FREQ 1%@665 GR3D_FREQ 11%@305 GR3D2_FREQ 11%@0 NVJPG1 729 VIC_FREQ 115 APE 233 CV0@-256C CPU@47.5C Tboard@36C SOC2@45.156C Tdiode@37.75C SOC0@44.406C CV1@-256C GPU@43.562C tj@47.5C SOC1@45.062C CV2@-256C VDD_GPU_SOC 3184mW/3184mW VDD_CPU_CV 796mW/796mW VIN_SYS_5V0 4226mW/4276mW NC 0mW/0mW VDDQ_VDD2_1V8AO 704mW/704mW NC 0mW/0mW
09-14-2022 09:27:33 RAM 914/30536MB (lfb 7177x4MB) SWAP 0/15268MB (cached 0MB) CPU [12%@729,4%@729,1%@729,27%@729,0%@729,0%@729,0%@729,0%@729,off,off,off,off] EMC_FREQ 1%@665 GR3D_FREQ 22%@305 GR3D2_FREQ 22%@0 NVJPG1 729 VIC_FREQ 115 APE 233 CV0@-256C CPU@47.656C Tboard@36C SOC2@45.031C Tdiode@37.75C SOC0@44.531C CV1@-256C GPU@43.843C tj@47.531C SOC1@44.906C CV2@-256C VDD_GPU_SOC 3184mW/3184mW VDD_CPU_CV 796mW/796mW VIN_SYS_5V0 4327mW/4293mW NC 0mW/0mW VDDQ_VDD2_1V8AO 704mW/704mW NC 0mW/0mW
09-14-2022 09:27:34 RAM 914/30536MB (lfb 7177x4MB) SWAP 0/15268MB (cached 0MB) CPU [6%@729,3%@729,0%@729,34%@729,0%@729,0%@729,0%@729,0%@729,off,off,off,off] EMC_FREQ 2%@665 GR3D_FREQ 11%@305 GR3D2_FREQ 11%@0 NVJPG1 729 VIC_FREQ 115 APE 233 CV0@-256C CPU@47.468C Tboard@36C SOC2@45.156C Tdiode@37.75C SOC0@44.406C CV1@-256C GPU@43.531C tj@47.468C SOC1@45C CV2@-256C VDD_GPU_SOC 3184mW/3184mW VDD_CPU_CV 796mW/796mW VIN_SYS_5V0 4226mW/4276mW NC 0mW/0mW VDDQ_VDD2_1V8AO 704mW/704mW NC 0mW/0mW
09-14-2022 09:27:35 RAM 914/30536MB (lfb 7177x4MB) SWAP 0/15268MB (cached 0MB) CPU [4%@729,2%@729,0%@729,31%@729,0%@729,0%@729,0%@729,0%@729,off,off,off,off] EMC_FREQ 2%@665 GR3D_FREQ 13%@305 GR3D2_FREQ 13%@0 NVJPG1 729 VIC_FREQ 115 APE 233 CV0@-256C CPU@47.562C Tboard@36C SOC2@45C Tdiode@37.75C SOC0@44.375C CV1@-256C GPU@43.781C tj@47.562C SOC1@44.937C CV2@-256C VDD_GPU_SOC 3184mW/3184mW VDD_CPU_CV 796mW/796mW VIN_SYS_5V0 4226mW/4266mW NC 0mW/0mW VDDQ_VDD2_1V8AO 704mW/704mW NC 0mW/0mW
This probably needs other users to share experience. Looks like something wrong at application level.
We have nvegglessink in gstreamer and it supports X11 and Wayland. You may try Wayland and see if you observe the issue.
Unfortunately Openbox or Fluxbox are not compatible with Wayland…
