Jetson Orin AGX PCIe Endpoint mode ping issues
I make some experiments with two Orin AGX connected via PCIe and have a few issues. First of all I use the latest Jetpack 6.2 on both sides and configure Ethernet interface via PCIe. Everything works fine, iperf3 gives me 7.05 Gbits/sec bitrate when EP is a server and about 4 Gbits/sec when RP is a server. However, I am completely not satisfying with ping results:
rtt min/avg/max/mdev = 1.789/3.090/3.838/0.923 ms
Here is a ping output from RP to EP and I get almost the same results when I run ping from EP to host.
Is it correct? Are there any limitations why I get a PCIe ping much higher than even a direct ping via Ethernet cable?
The second issue I have is when I turn off or reboot the EP my RP kernel freezes and crashes with this dmesg log:
[  999.550259] pcieport 0005:00:00.0: AER: Uncorrected (Fatal) error received: 0005:00:00.0
[  999.550280] pcieport 0005:00:00.0: PCIe Bus Error: severity=Uncorrected (Fatal), type=Transaction Layer, (Receiver ID)
[  999.550283] pcieport 0005:00:00.0:   device [10de:229a] error status/mask=00000020/00400000
[  999.550285] pcieport 0005:00:00.0:    [ 5] SDES                   (First)
[  999.550295] tvnet 0005:01:00.0: AER: can't recover (no error_detected callback)
Are there any ways to fix this?
