Jetson orin agx , usb camera /dev/video0 no such file
I’ve developed on Jetson Orin AGX Develop kit.
Also I’ll try to connect camera from Basler. develop configuration like below.
model: acA4024-29uc, sensor is imx226
installed pylon version: 7.4.0
ubuntu 20.04,
cat /etc/nv_tegra_release → # R35 (release), REVISION: 1.0
but, I cannot connect basler camera.
I checked like this whether camera connected or not.
$lsusb → Bus 002 Device 003: ID 2676:ba02 Basler AG ace
$(pylon) nvidia@ubuntu:~/Downloads$ ls -al /dev/video*
ls: cannot access ‘/dev/video*’: No such file or directory
NVIDIA jetson jetpack supporting camera driver for balser above camera model(acA4024-29uc, imx226)?
Very pleasure any kind of suggestion or solutions, Thanks.
hello peterparker,
it looks using USB interface, which should be plug-n-play.
it’s more like an issue from sensor side, please contact with sensor vendor to confirm the validate L4T release version.
Thank you for your comment,
As you commented, I contacted with sensor vendor and I can take solutions.
