I am trying to get the video stream from the IMX390-GMSL camera, but facing the same issue as described here, could you please help me to understand which dtsi file to use and how to get the video?
Check below document to modify the device tree.
Thanks a lot for pointing me to the right resources to learn, let me try to the desired modification.
I assume that IMX390 dtsi will be available on L4T BSP source files right?
Thank you in advance @ShaneCCC !
Yes
