We are using a mipi camera (OCHSA10) under jetson AGX Orin and Xavier, drawing the camera adapter plate according to the pin definition of the Jetson motherboard. Under Xavier, the camera can light up, but under Orin, the DN end of the camera mipi (1.2V) cannot detect power supply. The pins we use are CSI1_D0, CSI1_CLK. Is there any difference between Orin and Xavier in the use of mipi pins?
The CSI1 pins usage on Orin is same to Xavier. Please confirm the port-index is the same.
