Jetson orin (devkit 64GB) cannot run the cross compiled program of ue5.1.1
So no one has still been able to yet run Unreal on an nVidia AGX Orin 64GB?
any news?
I’m having some download problems installing Vulkan-Samples.
git clone --recurse-submodules GitHub - KhronosGroup/Vulkan-Samples: One stop solution for all Vulkan samples :
I encounter interruptions when downloading some submodules.
Even if I choose to download the Vulkan-Samples-main.zip file and run “cmake -G “Unix Makefiles” -Bbuild/linux -DCMAKE_BUILD_TYPE=Release”, it will prompt errors:
Have you encountered this issue?
Anyway, I will continue to work on this problem.
32GB_VulkanDebug.txt (72.1 KB)
64GB_VulkanDebug.txt (64.1 KB)
I turn on these environment variables.
32GB returns 1000348013 as does 64GB. 32GB will have some other logs (32GB doesn’t run successfully with -VulkanDebug turned on).
see .txt for details.
Internet connection must have been interrupted. You can remove the folder and try this command again.
Anything? Are we simply accepting that 64GB Jetson AGX Orin’s can’t run Unreal deployments? Do we have to wait until the next version of devices from nVidia?
We are investigating the issue:
Jetson AGX Orin unreal engin vulkan problem
Will update when there’s further finding.
Please upgrade to Jetpack 6.0GA(r36.3) and try again. The failure on AGX Orin 64GB shall be fixed.
The fix does not catch 6.0GA. We are checking further and will update.
Please use 6.0GA(r36.3) and apply this prebuilt lib:
Jetson Linux 36.3 | NVIDIA Developer
Additional Files
overlay_libcuda_36.3.tbz2
And try again.
