Jetson orin flash:command terminated with error
I am experiencing a failure while flashing the Jetson Orin Nano Developer Kit.
Could you please provide a solution?"
SDKM_logs_JetPack_6.0_(rev._1)_Linux_for_Jetson_Orin_Nano_modules_2024-06-11_07-08-51.zip (567.6 KB)
Are you using VM or a native Ubuntu OS PC?
Error: Could not stat device /dev/nvme0n1 - No such file or directory.
Check your disk.
Sorry, I had set the SD card in the device but selected NVMe in SDK Manager.
After selecting the SD card, the flash completed correctly.
Thank you for your support.
