We are using developer kit properly and there is no problem.But we have new JETSON ORIN INDUSTRIAL 64 GB module.When I tried to use dev kit with this module I could not see anything both serial channel and DP channel.Should I change anything on the dev kit to use JETSON ORIN INDUSTRIAL 64 GB?
info: there is 3.3V on the dev kit to SYS_VIN_SV
The AGX Orin industrial module was supported from JetPack 5.1.2/BSP 35.4.1.
May I know which JetPack SW you’re using?
Can’t we use default module setups? Should I do something to activate the module.Is there any BIOS or something inside the module?
Please download SDK Manager to your host and follow user guide steps to re-flash BSP on AGX-Orin industrial module.
Download link: SDK Manager | NVIDIA Developer
User Guide: NVIDIA SDK Manager Documentation — SDK Manager 2.1.0 documentation
Install Jetson Software with SDK Manager — SDK Manager 2.1.0 documentation
