Platform: Jetson Orin
JetPack version: JetPack 7.2
Board: Customer custom carrier board
PD controller: TUSB321AI, PORT pin pulled up, configured as DFP mode
Issue: Type-C reverse insertion causes abnormal PD controller CC behavior and inconsistent USB Composite Device enumeration on the same hardware
Hi NVIDIA team,
We are debugging a USB Type-C reverse-insertion issue on a customer custom Jetson Orin board running JetPack 7.2. The PD controller is TUSB321AI. The PORT pin is pulled up to VDD_SYS_5V, so the PD chip is configured as DFP mode and should internally pull up the CC pins.
We are doing Type-C front/reverse insertion validation on the same hardware and observed inconsistent behavior.
Schematic / design notes:
TUSB321AI is used for Type-C OTG/host detection.
PORT pin is pulled up, so the PD chip is forced into DFP mode.
ORIN_TYPEC_ID is connected through a resistor divider to ORIN_TYPEC_ID_1V8.
SOC_U3_1_CC1_A and SOC_U3_1_CC2_A are connected to the Orin CC1/CC2 pins.
The UDC controller is initially configured as device mode.
Test results:
1. Board powered on, no cable connected
After power-on, both CC1 and CC2 are pulled up on the board side.
However, the UDC controller is initially configured as device mode.
Is this expected on Jetson Orin with JetPack 7.2? Should the UDC mode be configured dynamically based on CC status or PD controller interrupt?
2. Cable connected, PC as Host, board not powered on
Front insertion:
- From the PC side, CC1 is pulled down to 0 V on one side only. This looks normal.
Reverse insertion:
- From the PC side, CC2 is pulled down to 0 V on one side only. This also looks normal.
So before the board is powered on, the PC side sees normal Host behavior in both orientations.
3. After the board is powered on
Front insertion:
CC pins are both pulled up to about 5 V because the PD controller is in DFP mode and pulls up both CC pins.
The PC does not recognize a USB Composite Device. We understand this may be normal because both sides are now DFP / pulled up.
Reverse insertion:
CC pins are also both pulled up to about 5 V.
But the PC does recognize a USB Composite Device. This is abnormal.
The abnormal case is: after power-on, in reverse insertion, the CC pins are both pulled up to about 5 V, but the PC still enumerates a USB Composite Device. This suggests the PD controller internal logic may be confused, or the Type-C orientation detection is not handled correctly.
Questions:
For Jetson Orin Type-C OTG/host design on JetPack 7.2, is it correct to force TUSB321AI into DFP mode by pulling PORT high?
How should the Orin UDC controller mode be configured when the board is powered on but no cable is connected? We see both CC pins pulled up, but UDC still initializes as device mode. Is this a software configuration issue?
Why does reverse insertion after power-on still allow the PC to enumerate a USB Composite Device even though both CC pins are pulled up to about 5 V? Is this a known issue with TUSB321AI or with the Orin Type-C configuration?
What is the recommended CC/PD configuration for Jetson Orin Type-C host/OTG reverse insertion? Should we change the PORT pin strap, CC pull-up strategy, or use a different PD controller?
Are there any Orin-specific requirements for Type-C CC1/CC2 routing, ID pin handling, or UDC mode switching that we should check on a custom carrier board?
