Dear NVIDIA Support,
We are experiencing an issue while upgrading Jetson Linux (L4T) on our Jetson Orin-based custom board (MSTL / Neuron HDMI A01). During sudo apt-get upgrade, key L4T packages such as:
nvidia-l4t-bootloadernvidia-l4t-kernelnvidia-l4t-jetson-io, etc.
fail to configure, showing the following error:
ERROR. 3767-000-0000--1--mstl-neuron-orin-hdmi-a01- does not match any known boards.
Board Info:
- TNSPEC: 3767-301-0000-G.1-1-1-mstl-neuron-orin-hdmi-a01-
- COMPATIBLE_SPEC: 3767-000-0000–1–mstl-neuron-orin-hdmi-a01-
Note:
This same board and software stack were working fine earlier. We haven’t made any changes to the software, BSP, or configuration from our side. The issue started only after a recent system update (apt-get upgrade).
We suspect this could be due to:
- A change in recent L4T packages (especially post-install checks)
- Or missing board ID recognition for this custom hardware
We’ve attached the full failure log for your reference.
Kindly advise on:
- Whether this is a known regression or board check change
- How to safely bypass or patch this issue
- If BSP overlay updates are required for our board ID
Environment:
- Jetson Linux R36.4.4 (L4T 36.4.4)
- Ubuntu 22.04 (host)
Please find the attached failure logs (upgrade-fail-log.txt) for review.
Looking forward to your guidance.
with regards,
Sunil
@DaneLLL
jetson_orin_upgrade_err.txt (8.3 KB)
