Then this method is not correct.
UEFI and kernel dtb are in different partition.
Update the device tree on your host and then do full flash…
Then this involves another problem of machine brushing; If I provide the kernel and dtb files in Linux_for_Tegra/bootloader, the machine cannot be started…
You should put the dtb under Linux_for_Tegra/kernel/dtb.
thk!!!
have already been solved
