We are using a custom board to adapter camera on Jetson AGX Orin Developer Kit.
This custom board is verified and work fine on Jetson AGX Xavier Developer Kit.
But this custom board need to change Brick config in csi5_fops.c
brick_config.lane_polarity[0] = NVCSI_CPHY_POLARITY_CAB; //Trio1
brick_config.lane_polarity[1] = NVCSI_CPHY_POLARITY_BCA; //Trio2
brick_config.lane_polarity[2] = NVCSI_CPHY_POLARITY_CAB; //Trio3 not used
brick_config.lane_polarity[3] = NVCSI_CPHY_POLARITY_CAB; //Trio4
brick_config.lane_swizzle = NVCSI_LANE_SWIZZLE_A0A1B1B0;
I am to change csi5_mipi_cal for Xavier like down,It’s work fine.
cila =
(0x01 << CSI5_E_INPUT_LP_IO1_SHIFT) |
(0x01 << CSI5_E_INPUT_LP_IO0_SHIFT) |
(0x00 << CSI5_E_INPUT_LP_CLK_SHIFT) |
(0x01 << CSI5_PD_CLK_SHIFT) |
(0x00 << CSI5_PD_IO1_SHIFT) |
(0x00 << CSI5_PD_IO0_SHIFT);
cilb =
(0x00 << CSI5_E_INPUT_LP_IO0_SHIFT) |
(0x01 << CSI5_PD_IO0_SHIFT);
But Orin is not support csi5_mipi_cal now?
It’s show not calibration.
# tracer: nop
# entries-in-buffer/entries-written: 80/80 #P:12
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:4-522 [000] .... 80.582371: rtcpu_dbg_set_loglevel: tstamp:2935948392 old:0 new:2
v4l2-ctl-1713 [011] .... 81.247494: tegra_channel_open: vi-output, cphycam2-0032
v4l2-ctl-1713 [011] .... 81.269180: vb2_qbuf: owner = 0000000051ee2610, queued = 1, owned_by_drv = 0, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269184: v4l2_qbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [011] .... 81.269195: vb2_qbuf: owner = 0000000051ee2610, queued = 2, owned_by_drv = 0, index = 1, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269196: v4l2_qbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [011] .... 81.269201: vb2_qbuf: owner = 0000000051ee2610, queued = 3, owned_by_drv = 0, index = 2, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269201: v4l2_qbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [011] .... 81.269204: vb2_qbuf: owner = 0000000051ee2610, queued = 4, owned_by_drv = 0, index = 3, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269204: v4l2_qbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [011] .... 81.269214: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 1, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269215: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 2, index = 1, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269215: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269216: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [011] .... 81.269219: tegra_channel_set_power: cphycam 2-0032 : 0x1
v4l2-ctl-1713 [011] .... 81.269227: camera_common_s_power: status : 0x1
v4l2-ctl-1713 [000] .... 81.273769: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-1713 [000] .... 81.273773: csi_s_power: enable : 0x1
v4l2-ctl-1713 [000] .... 81.274760: tegra_channel_capture_setup: vnc_id 0 W 4096 H 3072 fmt c4
v4l2-ctl-1713 [000] .... 81.275343: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-1713 [000] .... 81.285178: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-1713 [000] .... 81.285180: csi_s_stream: enable : 0x1
v4l2-ctl-1713 [000] .... 81.285690: tegra_channel_set_stream: cphycam 2-0032 : 0x1
kworker/0:4-522 [000] .... 81.314338: rtcpu_vinotify_event: tstamp:2959337761 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:94688750368 data:0xc55cff0010000000
kworker/0:4-522 [000] .... 81.314339: rtcpu_vinotify_event: tstamp:2959337922 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:94688757504 data:0x0000000031000001
kworker/0:4-522 [000] .... 81.314339: rtcpu_vinotify_event: tstamp:2959338075 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:94688807584 data:0xc55cfc0010000000
kworker/0:4-522 [000] .... 81.314340: rtcpu_vinotify_event: tstamp:2959338206 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:94688814816 data:0x0000000031000002
kworker/0:4-522 [000] .... 81.426344: rtcpu_nvcsi_intr: tstamp:2963187896 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-522 [000] .... 81.426351: rtcpu_nvcsi_intr: tstamp:2963192902 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x20000000
kworker/0:4-522 [000] .... 81.426355: rtcpu_nvcsi_intr: tstamp:2963193280 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x40000000
kworker/0:4-522 [000] .... 81.426357: rtcpu_nvcsi_intr: tstamp:2963197416 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x40000000
vi-output, semi-1715 [002] .... 83.934584: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.934599: vb2_dqbuf: owner = 0000000051ee2610, queued = 3, owned_by_drv = 3, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.934605: v4l2_dqbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|ERROR|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [004] .... 83.934666: vb2_qbuf: owner = 0000000051ee2610, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.934667: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 4, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.934671: v4l2_qbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
vi-output, semi-1715 [002] .... 83.935506: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 25165824, timestamp = 0
vi-output, semi-1715 [002] .... 83.935511: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 2, index = 1, type = 1, bytesused = 25165824, timestamp = 0
vi-output, semi-1715 [002] .... 83.935512: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 1, index = 2, type = 1, bytesused = 25165824, timestamp = 0
vi-output, semi-1715 [002] .... 83.935514: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 0, index = 3, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935516: vb2_dqbuf: owner = 0000000051ee2610, queued = 3, owned_by_drv = 0, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935516: v4l2_dqbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|ERROR|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [004] .... 83.935531: vb2_qbuf: owner = 0000000051ee2610, queued = 4, owned_by_drv = 0, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935531: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 1, index = 0, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935533: v4l2_qbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [004] .... 83.935534: vb2_dqbuf: owner = 0000000051ee2610, queued = 3, owned_by_drv = 1, index = 1, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935534: v4l2_dqbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|ERROR|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 1
v4l2-ctl-1713 [004] .... 83.935540: vb2_qbuf: owner = 0000000051ee2610, queued = 4, owned_by_drv = 1, index = 1, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935540: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 2, index = 1, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935540: v4l2_qbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [004] .... 83.935541: vb2_dqbuf: owner = 0000000051ee2610, queued = 3, owned_by_drv = 2, index = 2, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935542: v4l2_dqbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|ERROR|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 2
v4l2-ctl-1713 [004] .... 83.935547: vb2_qbuf: owner = 0000000051ee2610, queued = 4, owned_by_drv = 2, index = 2, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935547: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 3, index = 2, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935547: v4l2_qbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
v4l2-ctl-1713 [004] .... 83.935548: vb2_dqbuf: owner = 0000000051ee2610, queued = 3, owned_by_drv = 3, index = 3, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935549: v4l2_dqbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|ERROR|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 3
v4l2-ctl-1713 [004] .... 83.935554: vb2_qbuf: owner = 0000000051ee2610, queued = 4, owned_by_drv = 3, index = 3, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935554: vb2_buf_queue: owner = 0000000051ee2610, queued = 4, owned_by_drv = 4, index = 3, type = 1, bytesused = 25165824, timestamp = 0
v4l2-ctl-1713 [004] .... 83.935555: v4l2_qbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 25165824, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
vi-output, semi-1715 [002] .... 83.936594: tegra_channel_capture_setup: vnc_id 0 W 4096 H 3072 fmt c4
kworker/0:4-522 [000] .... 83.954268: rtcpu_vinotify_event: tstamp:3042341010 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:97350078080 data:0xc55cff0010000000
kworker/0:4-522 [000] .... 83.954280: rtcpu_vinotify_event: tstamp:3042341151 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:97350085216 data:0x0000000031000001
kworker/0:4-522 [000] .... 83.954286: rtcpu_vinotify_event: tstamp:3042341304 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:97350124256 data:0xc55cfc0010000000
kworker/0:4-522 [000] .... 83.954289: rtcpu_vinotify_event: tstamp:3042341436 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:97350131456 data:0x0000000031000002
v4l2-ctl-1713 [005] .... 84.984248: tegra_channel_close: vi-output, cphycam 2-0032
vi-output, semi-1715 [002] .... 86.462983: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 3, index = 0, type = 1, bytesused = 25165824, timestamp = 0
vi-output, semi-1715 [002] .... 86.463548: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 2, index = 1, type = 1, bytesused = 25165824, timestamp = 0
vi-output, semi-1715 [002] .... 86.463551: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 1, index = 2, type = 1, bytesused = 25165824, timestamp = 0
vi-output, semi-1715 [002] .... 86.463552: vb2_buf_done: owner = 0000000051ee2610, queued = 4, owned_by_drv = 0, index = 3, type = 1, bytesused = 25165824, timestamp = 0
vi-output, semi-1715 [002] .... 86.464748: tegra_channel_capture_setup: vnc_id 0 W 4096 H 3072 fmt c4
v4l2-ctl-1713 [005] .... 86.465523: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-1713 [005] .... 86.465531: tegra_channel_set_stream: cphycam 2-0032 : 0x0
v4l2-ctl-1713 [005] .... 86.466123: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-1713 [005] .... 86.466129: csi_s_stream: enable : 0x0
v4l2-ctl-1713 [000] .... 86.477823: tegra_channel_set_power: cphycam 2-0032 : 0x0
v4l2-ctl-1713 [000] .... 86.477877: camera_common_s_power: status : 0x0
v4l2-ctl-1713 [005] .... 86.487387: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-1713 [005] .... 86.487397: csi_s_power: enable : 0x0
