我已经成功的将IMX586摄像头的驱动文件和设备树文件复制到了正确的位置,并且成功flash
大概步骤如下:
1.在tegra_defconfig文件中增加配置选项
2.将驱动文件复制到media/i2c路径下,并在makefile和kconfig中添加对应的信息
3.将dtsi文件复制到t23x/p3767/cvb下,并在顶层设备树文件中包含imx586设备树头文件
当我启动设备后,使用sudo dmesg |grep -i imx命令,可以看到内核执行了imx586的驱动文件:
nvidia-user@tegra-ubuntu:~/Desktop$ sudo dmesg |grep -i imx
[sudo] password for nvidia-user:
[ 11.708089] imx586 2-001a: imx586_probe : probing v4l2 sensor, i2c-2, 3 mode
[ 11.708447] imx586 2-001a: tegracam sensor driver:imx586_v2.0.6
[ 11.708451] imx586 2-001a: imx586_probe : tegracam_device_register end!!!--------
[ 11.708454] imx586 2-001a: imx586_board_setup start !!!------------
[ 11.711474] imx586 2-001a: imx586_board_setup camera_common_mclk_enable end !!!------------
[ 11.711496] imx586_power_on: power_on
[ 11.711498] imx586 2-001a: imx586_power_on: set reset gpio = 397.
[ 11.711683] imx586 2-001a: imx586_board_setup imx586_power_on end !!!------------
[ 11.711688] imx586 2-001a: imx586_probe : imx586_board_setup end!!!--------
[ 11.711692] imx586 2-001a: imx586_probe : ctrlprops->gain_factor = 10, ctrlprops->framerate_factor = 1000000,ctrlprops->inherent_gain = 1!--------
[ 11.711697] imx586 2-001a: imx586_probe : ctrlprops->min_gain_val = 10, ctrlprops->max_gain_val = 240,ctrlprops->min_hdr_ratio = 1, ctrlprops->max_hdr_ratio = 1 !--------
[ 11.711703] imx586 2-001a: imx586_probe : ctrlprops->min_framerate = 1000000, ctrlprops->max_framerate = 30003939,ctrlprops->step_gain_val = 1, ctrlprops->step_framerate = 1 !--------
[ 11.711708] imx586 2-001a: imx586_probe : ctrlprops->exposure_factor = 1000000, ctrlprops->default_gain = 10,ctrlprops->default_framerate = 30003939, ctrlprops->is_interlaced = 0, ctrlprops->interlace_type = 0 !--------
[ 11.711714] imx586 2-001a: imx586_probe : ctrlprops->min_exp_time = 32 !--------
[ 11.711718] imx586 2-001a: imx586_probe : ctrlprops->max_exp_time = 33333 !--------
[ 11.711722] imx586 2-001a: imx586_probe : ctrlprops->step_exp_time = 2 !--------
[ 11.711726] imx586 2-001a: imx586_probe : ctrlprops->default_exp_time = 33333 !--------
[ 11.711730] imx586 2-001a: imx586_probe: frame_length:0, numctrls:0, mode_prop_idx:0, mode:0, csi_port:0, numlanes:4, numfmts: 7, def_mode: 0, def_width: 4000, def_height:3000, def_clk_freq:24000000, fmt_width: 4000, fmt_height:3000
[ 11.711739] imx586 2-001a: imx586_probe: framerates:30, num_framerates:1, mode:0, hdr_en:1
[ 11.712292] imx586 2-001a: imx586_write_reg: i2c write reg failed, addr: 0x0204, val: 00, err: -121
[ 11.712300] imx586 2-001a: Error -121 in control hdl setup
[ 11.712308] imx586 2-001a: Failed to init ctrls imx586
[ 11.712311] imx586 2-001a: tegra camera subdev registration failed
[ 11.722088] imx586: probe of 2-001a failed with error -121
不幸的是,出现了错误,出现问题的函数是:
imx586_probe() → tegracam_v4l2subdev_register() → tegracam_ctrl_handler_init()
根据我的判断,似乎是i2c的连接出现了问题,因为当我使用i2cdetect -l后,信息如下:
nvidia-user@tegra-ubuntu:~/Desktop$ sudo i2cdetect -l
i2c-3 i2c 3190000.i2c I2C adapter
i2c-1 i2c c240000.i2c I2C adapter
i2c-8 i2c 31e0000.i2c I2C adapter
i2c-6 i2c 31c0000.i2c I2C adapter
i2c-4 i2c Tegra BPMP I2C adapter I2C adapter
i2c-2 i2c 3180000.i2c I2C adapter
i2c-0 i2c 3160000.i2c I2C adapter
i2c-9 i2c NVIDIA SOC i2c adapter 0 I2C adapter
i2c-7 i2c c250000.i2c I2C adapter
i2c-5 i2c 31b0000.i2c I2C adapter
在imx586的设备树节点中,使用的是3180000和31e0000
i2c@3180000 {
imx586_a@34 {
// cam0_mclk
clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA234_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
clock-frequency = <24000000>;
//status = "okay";
reset-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>; //also for VCM_2V8 en
i2c@31e0000 {
imx586_c@34 {
// cam1_mclk
clocks = <&bpmp_clks TEGRA234_CLK_EXTPERIPH2>,
clock-names = "extperiph2", "pllp_grtba";
mclk = "extperiph2";
//status = "okay";
reset-gpios = <&tegra_main_gpio CAM1_PWDN GPIO_ACTIVE_HIGH>; //also for VCM_2V8 en
但是当我使用 sudo i2cdetect -y 2这个命令后,并没有检测到地址,并且在内核的日志信息中
告诉了我往imx586的0x0204进行地址写是失败的,所以我怀疑是i2c有问题
但是我不清楚具体问题出在哪里,是否是设备树文件不合适
如果有需要的话我可以上传我的设备树文件
