Jetson Orin Nano 8GB developer kit
Hello Everyone, so we are using jetson orin nano 8gb in which we are processing 4 different AI models with the help of python, but after one month or so, the jetson is going of somekind of error is coming and the jetson is not booting up properly.
Please find attached screenshot of the error and the serial debug console log which have been extracted through RS/TX pins.
putty.log (35.8 KB)
Based on the provided information, it appears that you are experiencing issues with your Jetson Orin Nano 8GB device, specifically with booting up and processing AI models using Python. The error message and serial debug console log are attached, but unfortunately, I couldn’t access the attachments. However, I’ll provide a comprehensive answer based on the context.
Possible Causes:
  1. Software Issues: The error might be related to software conflicts, corrupted files, or incompatible dependencies. Since you’re running multiple AI models using Python, it’s possible that there are conflicts between the models or dependencies.
  2. Hardware Issues: The Jetson Orin Nano 8GB device might be experiencing hardware-related problems, such as overheating, power supply issues, or faulty components.
  3. Firmware Issues: Firmware corruption or outdated firmware might be causing the booting issues.
Troubleshooting Steps:
  1. Check the Serial Debug Console Log: Analyze the log to identify any specific error messages or patterns that might indicate the cause of the issue.
  2. Verify Software Dependencies: Ensure that all dependencies required by the AI models are compatible and up-to-date.
  3. Run a System Update: Update the Jetson Orin Nano 8GB device to the latest firmware and software versions.
  4. Check for Overheating: Monitor the device’s temperature to ensure it’s within the recommended range.
  5. Power Cycle: Try power cycling the device to see if it resolves the issue.
  6. Reflash the Device: If the issue persists, try reflashing the device with the latest firmware.
Comparison with Similar Issues:
Based on the provided context, it seems that the issue is similar to the ones reported in the following topics:
  • “Jetson Orin Nano Developer Kit – Black Screen and Fan Stops After Boot (JetPack 5.1.3)”
  • “Booting issue Jetson Orin Nano boot, jetson”
  • “Assertion issue in UEFI during boot Jetson AGX Orin jetson, kb”
These topics suggest that booting issues can be caused by a variety of factors, including software conflicts, firmware corruption, and hardware problems.
Recommendations:
  1. Consult the NVIDIA Documentation: Refer to the official NVIDIA documentation for the Jetson Orin Nano 8GB device to ensure that you’re following the recommended setup and troubleshooting procedures.
  2. Seek Community Support: Reach out to the NVIDIA developer community or forums for assistance with troubleshooting and resolving the issue.
  3. Contact NVIDIA Support: If the issue persists, consider contacting NVIDIA support for further assistance.
By following these steps and recommendations, you should be able to identify and resolve the issue with your Jetson Orin Nano 8GB device.
What is your JP/BSP version?
  1. BSP (L4T): 36.2.0
  2. JP: 6.0 DP
We suggest to upgrade to the latest version (36.4.4).
