Jetson orin nano 8GB won't boot
I connected a brand new Jetson orin nano 8GB module (900-13767-0030-000) to the carrier board of the NVIDIA-JETSON-ORIN-NANO-DEVKIT. i am trying to boot with the SSD, but UEFI will not boot.
If I use the same SSD and carrier board and use the orin nano that came with the NVIDIA-JETSON-ORIN-NANO-DEVKIT, it boots correctly.
Is the 900-13767-0030-000 UEFI broken?
Or do I need another process to use the new Jetson orin nano with the existing SSD?
When I connect the non-booting Jetson to another Ubuntu PC in recovery mode, isusb outputs "0955:7523 NVIDIA Corp. APX.
I have reflashed the SSD with the non-booting jetson, but the situation has not changed.
I referred to the following URL. (jp5.1.2)
What is your jetpack version?
it is JetPack5.1.2
We suggest to flash your new module to the latest version like JP5.1.5 or JP6.2 to cross check whether the issue exist.
I am investigating about flash.sh.
Regarding writing to internal (Jetson), is it possible that the new Jetson orin nano will not start because nothing is written to the SPI flash?
There is a section about how to flash qspi only
