Jetson Orin Nano application stops reading files from SD card while process remains running, followed by severe Wi-Fi communication issues
Hello NVIDIA community,
I am experiencing a strange issue with a Jetson Orin Nano and would appreciate any advice on how to diagnose it.
System
  • Jetson Orin Nano
  • JetPack / L4T: 6.2.1/36.4.7
  • Ubuntu: 22.04
  • Boot/storage: microSD card
  • Wi-Fi communication with a PC
Problem
My project consists of several small applications running simultaneously.
One application (A) periodically reads multiple image files from an SD card at specific timestamps and processes them.
The system initially works normally. However, after running for some time, application A suddenly stops doing its actual work.
The interesting part is that the application process itself is still running. It does not crash or exit, but it stops reading/processing the images.
For example:
Application A: RUNNING
Scheduled time arrives
Expected: Read images from SD card
Nothing happens / no further progress
I checked both the application logs and Ubuntu system logs, but I could not find any obvious error corresponding to the failure.
Wi-Fi issue
After a while, I also noticed that communication between the Jetson and my PC became extremely unreliable.
The Wi-Fi connection does not necessarily disconnect completely. Some commands work, while other commands are extremely slow or hang.
This makes me wonder whether the SD-card problem and the network problem could be symptoms of a larger system-level issue rather than an application-specific problem.
I would appreciate any suggestions for determining whether this is an SD-card/hardware issue, MMC driver issue, filesystem issue, resource exhaustion, or something else.
Thank you.
Besides the application, are you still be able to access your board?
The board is rubbed, but the card is alive.
How about dumping the log first? Are you able to physically access the board and connect UART serial cable?
Looks like you don’t know the status of your board either. You just feel it does not respond to you.
Hi @WayneWWW ,
The board is already destroyed.
so… what kind of help do you need here…? We could not check anything with just such comments.
Need software log to clarify.
The cards are alive, but the board is destroyed, so I don’t really know either.
I just want to know if anyone else has experienced something like this.
How did you tell your board is “destroyed”?
Do you see an obvious hardware components broken?
The device does not boot.
It does not mean something is destroyed… You could just reflash the board to make it bootable again…
Use sdkmanager to flash it from another host PC.
Also, my previous suggestion to dump the log is still helpful… maybe the board is still bootable … It could be that you don’t know how to check it.
The circuit board burned because the device fell into water.
So I can’t operate the device.
OK. Then I think nothing we could do here.
