Jetson Orin Nano beeps continously, when plugged in, won't boot up and the Ethernet port has light on them
Hello There
I have been using Jetson Orin Nano for a few weeks now. It was working fine, when I plug it today, the fans are not rotating, the power LED are off, I can hear a continous beep sound coming from the board. Just add more the screw holding down the wifi Card heats up.
I tried to re flash it following these link .
I have used the jumper to connect FC REC with GND, plugged in Usb-C to the board and my laptop, then plugged in the DC power. Nothing comes up and the board beeps like something is going to explode (like on the movies). So I unplugged it and plugged it back in. But it doesn’t reboot and the board is beeping. I tried different power supplies but the Jetson does not turn on. Only the Ethernet port lights up bright and becomes dim and stays dim.
Is there a solution for this problem, Thank you.
Sorry for the late response.
