Jetson orin nano cam1 cannot display
Hell,Jetson:
Hello, I mentioned a case before.
Currently, the four-channel cameras of the first deserializer have been connected and are functioning. The second deserializer is being debugged, and it is connected to cam1.
and trace log and dts file
cam1-log.txt (7.8 KB)
cam-dts.txt (59.1 KB)
I have a few configuration points I need to confirm with you. The second deserializer’s four-channel cameras are configured on cam1, that is, on csi2/3, configured as 4-lane. At this time, can the vc-id be configured as 4, 5, 6, 7?
Can you identify where the issue of not displaying the image is based on the logs I provided? How should I troubleshoot and fix it?
thanks!
The trace log shows didn’t receive any validate data.
Maybe probe the signal and review the config.
