HELLO
Jetson_Orin_Nano_DevKit_Carrier_Board_Reference_Design_Files_A04_20230320.zip (P3578)
Is it permissible to use this compressed file for developing a Jetson Orin Nano schematic?
NOT-Jetson ORIN NX
HELLO
NOT-Jetson ORIN NX
The compressed file “JetsonOrinNanoDevKitCarrierBoardReferenceDesignFilesA0420230320zip” is specifically designed for the Jetson Orin Nano Developer Kit Carrier Board Reference Design. The P3578 is the part number for the Jetson Orin Nano module.
According to the provided context, the Jetson Orin NX and Jetson Orin Nano series modules are not pin-compatible with each other. However, it is possible to design a carrier board that supports both modules by using the common I/O interfaces.
In this case, the compressed file is intended for the Jetson Orin Nano, and it is not explicitly stated that it is compatible with the Jetson Orin NX. Therefore, it is not recommended to use this file for developing a Jetson Orin NX schematic.
If you need to develop a schematic for the Jetson Orin NX, you should look for reference design files specifically intended for the Jetson Orin NX. Using the wrong reference design files may lead to compatibility issues and potential errors in your design.
In summary, while the Jetson Orin Nano and Jetson Orin NX share some similarities, they are not pin-compatible, and you should use the correct reference design files for your specific module to ensure compatibility and accuracy in your design.
Here is a comparison of the two modules:
It is essential to use the correct reference design files for your specific module to ensure compatibility and accuracy in your design.
Yes that is the right package for the Dev Kit/reference carrier board for both Orin Nano and Orin NX. You can import the schematics design files into Concept or OrCAD to start with NVIDIA’s reference carrier and make your customizations.
If you use OrCAD, the design files are the base version (all components stuffed) so you need to apply the BOM first to get the correct component stuffing. You can refer to the Concept schematics PDF to see which components are used and which are open: P3768_A04_Concept_schematics.pdf
