Hi everyone,
I am working with a Jetson Orin Nano 8GB running JetPack/L4T 36.4.0
Problem
Initially, the captured image/data is correct. However, after running for some time:
- The image becomes corrupted/noisy.
- Captured frames can become misaligned/corrupted.
- Eventually, the CSI capture stream may stop.
Dmesg
After the stream starts failing, I repeatedly get the following messages:
[ 503.015287] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 503.015316] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 503.017090] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 508.135236] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 508.135266] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 508.137102] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 513.255001] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 513.255033] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 513.256806] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 518.374840] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 518.374867] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 518.376450] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 523.494485] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 523.494516] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 523.496036] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 528.614529] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 528.614556] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 528.616292] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 533.734346] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 533.734377] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 533.736216] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 538.854234] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 538.854263] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 538.856394] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 543.973804] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 5000 ms
[ 543.973829] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 543.975562] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
V4L2 trace
I also captured the V4L2 trace using the kernel tracing interface.
The trace shows that the captured buffers are being returned with the ERROR flag:
cap dqbuf: 0 seq: 1116 bytesused: 4147200 ts: 605.431340 delta: 16.657 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1117 bytesused: 4147200 ts: 605.447998 delta: 16.658 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1118 bytesused: 4147200 ts: 605.464655 delta: 16.657 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 1119 bytesused: 4147200 ts: 605.481312 delta: 16.657 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 1120 bytesused: 4147200 ts: 605.497970 delta: 16.658 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1121 bytesused: 4147200 ts: 605.514627 delta: 16.657 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1122 bytesused: 4147200 ts: 605.531285 delta: 16.658 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 1123 bytesused: 4147200 ts: 605.547942 delta: 16.657 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 1124 bytesused: 4147200 ts: 605.564615 delta: 16.673 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1125 bytesused: 4147200 ts: 605.647902 delta: 83.287 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1126 bytesused: 4147200 ts: 605.681293 delta: 33.391 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 1127 bytesused: 4147200 ts: 605.714593 delta: 33.300 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 1128 bytesused: 4147200 ts: 605.797804 delta: 83.211 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1129 bytesused: 4147200 ts: 605.814477 delta: 16.673 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1130 bytesused: 4147200 ts: 605.897764 delta: 83.287 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 1131 bytesused: 4147200 ts: 605.981067 delta: 83.303 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 1132 bytesused: 4147200 ts: 606.081012 delta: 99.945 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1133 bytesused: 4147200 ts: 606.280871 delta: 199.859 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1134 bytesused: 4147200 ts: 606.297543 delta: 16.672 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 1135 bytesused: 4147200 ts: 606.330858 delta: 33.315 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 1136 bytesused: 4147200 ts: 606.480791 delta: 149.933 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1137 bytesused: 4147200 ts: 606.514121 delta: 33.330 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1138 bytesused: 4147200 ts: 606.597378 delta: 83.257 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 1139 bytesused: 4147200 ts: 606.714011 delta: 116.633 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 1140 bytesused: 4147200 ts: 606.730668 delta: 16.657 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1141 bytesused: 4147200 ts: 606.830598 delta: 99.930 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1142 bytesused: 4147200 ts: 606.847255 delta: 16.657 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 1143 bytesused: 4147200 ts: 606.913870 delta: 66.615 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 1144 bytesused: 4147200 ts: 607.197032 delta: 283.162 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1145 bytesused: 4147200 ts: 607.363622 delta: 166.590 ms (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 1146 bytesused: 4147200 ts: 607.480209 delta: 116.587 ms (error, ts-monotonic, ts-src-eof)
Initially, the frame interval is approximately 16.67 ms, which is consistent with 60 FPS.
After some time, however, the frame intervals become highly irregular
My main question is:
What is the most likely root cause of this issue, and what should I check or change to fix it?
Thank you for your advice.
