I have a Jetson Orin Nano Developer Kit (P3768 carrier board) that stopped powering on immediately after it fell.
There is now:
- No green power LED
- No fan movement
- No boot/display
- No apparent visible damage, burnt component, or cracked PCB
I have been troubleshooting the power rails with a multimeter.
Power supply
The PSU is:
- 19.0 V
- 4.74 A
- 90 W
Measured directly at the PSU connector:
19.6 V
So the power supply appears OK.
DC jack / DC input
At the solder pins of the DC jack:
- GND pins have continuity to ground
- Positive pin measures 19.6 V
So the DC jack itself appears to be OK.
40-pin header measurements
With the complete Jetson assembled:
- 5V pins (pins 2/4): approximately 0–0.4 V
- 3.3V pin: initially approximately 1.45 V
- No power LED
I also checked continuity between 5V and GND:
- No continuity/beep
- I did not find an obvious short to ground.
At one point I measured roughly 98.5 kΩ between 5V and GND with the module installed.
Test without the Orin module
I removed the Orin Nano SOM/module completely and tested the carrier board by itself.
The situation remains essentially the same:
- DC input: 19.6 V
- 5V header: approximately 0–0.4 V
- 3.3V header: approximately 0–0.03 V
So removing the module does not cause the 5V rail to come back.
VDD_CVB / U3 area
Using the P3768-A04 assembly drawing, I located the area around U3 / PRE-REG 5V DC/DC.
I tested C321:
- One side: 19.6 V
- Other side: 0 V / GND
I also confirmed by continuity testing that one side of C321 is connected to the positive DC input.
So it appears that VDD_CVB / the ~19V input reaches the U3 input area, but VDD_5V_SYS is not being generated.
I have NOT yet probed U3’s small pins directly because I don’t want to accidentally short adjacent pins.
My current suspicion
The fault seems to be somewhere around:
DCIN/VDD_CVB → U3 5V pre-regulator → VDD_5V_SYS
rather than the PSU, DC jack, SSD, or Orin module itself.
Since the failure happened immediately after a physical fall, I’m wondering if there could be:
- a damaged U3 / 5V regulator,
- cracked solder joint,
- damaged inductor,
- missing/incorrect U3 ENABLE signal,
- or another protection component in the 5V power path.
Questions
Should
VDD_5V_SYS/ the 5V pins on the 40-pin header be present when the Orin module is removed from the P3768 carrier board? -
Given 19.6 V at C321/VDD_CVB but ~0 V on the 5V header, what would you recommend measuring next?
Is there a safe test point for:
- U3 VIN
- U3 EN
- U3 output / switching node
- VDD_5V_SYS
that is easier to probe than the IC pins themselves?
Is there a fuse, load switch, protection MOSFET, or other component between VDD_CVB and U3 that I should check?
Would measuring both sides of L44 be the appropriate next test?
Does this symptom strongly suggest a carrier-board failure, or could the absence of the SOM prevent the 5V pre-regulator from starting?
I have a multimeter and can perform additional voltage, resistance, diode-mode, and continuity measurements if you tell me which test points/components to check.
