I saw the datasheet of carrier board, there is was Main DC input supplying DC jack input (9 V-20 V), 3 A max.
so if i use DC-DC Step-Down Power Supply, to covert the voltage from 6s Lipo Battery 22.1V to 19V, will the orin nano dev kit be ok??
Buck Converter is
LM2596S with SMD LED DC-DC Step-Down Power Supply
- Input voltage: 3-40V
- Output voltage: 1.5-35V(Adjustable)
- Output current: Rated current is 2A, maximum 3A
- Switching Frequency: 150KHz
- Operating temperature:Industrial grade (-40 to +85 )
- Conversion efficiency: 92%(highest)
i will be giving the power using DC Jack it self
