Hi NVIDIA team,
I’m trying to install JetPack 7.2 (r39.2.0) on a brand-new NVIDIA Jetson Orin Nano Developer Kit, but the QSPI firmware update always fails.
Hardware
- Product: NVIDIA Jetson Orin Nano Developer Kit
- Developer Kit P/N: 945-13766-0005-000
- Module: P3766
- Brand new board (first boot)
- Factory firmware: 36.4.3
- Official NVIDIA power adapter
- microSD card inserted (blank)
- USB installer created using Balena Etcher
Installer
ISO image:
jetsoninstaller-r39.2.0-2026-06-01-23-53-13-arm64.iso
Current firmware shown during boot:
Jetson System firmware version 36.4.3-gcid-38968081
date 2025-01-08T01:18:20+00:00
Steps to reproduce
- Boot from the JetPack 7.2 installer USB.
- Open Boot Manager.
- Select UEFI General UDisk.
- The installer detects that a firmware update is required.
- Press Y to update the firmware.
- The installer reports:
*** NVIDIA QSPI Firmware Update Required ***
New FW version : 39.02.00
Current version : 36.04.03
User confirmed. Proceeding with capsule update.
Capsule update prepared, resetting the system in 2 seconds.
- The board reboots automatically.
Actual result
After reboot, the firmware version is still:
36.4.3
The firmware update never actually starts.
I never see any firmware update progress screen (such as “Updating Capsule…” or a progress percentage).
After several automatic reboot attempts, the installer stops with:
RunPreIsoInstaller: Capsule staged 5 times but version not bumped, aborting to prevent boot loop
L4TLauncher: Iso boot loop detected, halting
Display issue
I also noticed that there is no display output at any point during the installation process.
I tested both:
- DisplayPort → DisplayPort
- DisplayPort → HDMI
Neither configuration produces any video output.
Because of this, I have been using the UART serial console (Tera Term) to monitor the entire boot process.
I’m not sure whether the display issue is related to the firmware update failure.
What I have already tried
- Recreated the USB installer using Balena Etcher.
- Booted explicitly from Boot Manager → UEFI General UDisk.
- Confirmed the firmware update by pressing Y.
- Multiple reboot attempts.
- microSD card inserted.
- USB installer connected directly.
- UART serial console connected using Tera Term.
- Official NVIDIA power supply.
The firmware version always remains 36.4.3.
Additional observations
The UEFI also prints:
WARNING: Test UEFI variable auth key is being used!
and the boot banner identifies the platform as:
NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super
even though the hardware is an official Jetson Orin Nano Developer Kit.
Questions
- Is this a known issue with JetPack 7.2 on boards shipped with factory firmware 36.4.3?
- Why is the Capsule Update staged but never executed?
- Is there any workaround besides flashing the QSPI using SDK Manager?
- Is the following message expected on a retail Jetson Orin Nano Developer Kit?
- Is the lack of DisplayPort output related to the firmware update failure?
I’ve attached the complete UART serial log for reference.
jetson_orin_nano.log (415.1 KB)
Thank you.
