Hardware: Jetson Orin Nano Developer Kit Super variant
Serial: 1424924359547
JetPack: R39.2.0 (fresh flash, also occurred on R36.5.0)
Kernel: 5.15.185-tegra
GPU UUID: 497e512c-89ce-5a86-ade6-f7de8233865a
Three hardware-level issues, all persisting across JetPack versions and power cycles:
GPU DVFS completely non-functional
- “devfreq 17000000.gpu: dvfs failed with (-22) error” every ~30ms
- GPU stuck at 612 MHz in default mode
- All 8 available frequencies (306-1020 MHz) fail to set via userspace governor
- Only workaround: lock to performance governor at 918 MHz (bypasses DVFS entirely)
Display controller errors (from boot, no display changes affect it)
- “NVRM rpcRmApiControl_dce: Failed RM ctrl call cmd:0x731341 result 0xffff” every 5s
- “NVRM rpcRmApiControl_dce: Failed RM ctrl call cmd:0x730282 result 0x1f” every 5s
- Black screen after UEFI logo on connected display
GPU unstable under sustained CUDA load
- Small workloads pass (200x 2000x2000 matmuls)
- Full-resolution training (1024x1344, batch=2) crashes after 100 iterations
- Crash: NVML_SUCCESS == r INTERNAL ASSERT FAILED at CUDACachingAllocator.cpp:838
Temperatures well within spec (idle 48°C, load 65°C).
Official NVIDIA 15V/3A power supply, 19W draw under load.
No overclocking, no custom settings. Default nvpmodel mode 1 (25W).
NVIDIA live support (Adfar Banday) confirmed this appears to be a hardware-level fault and directed me here for forum review before RMA processing.
