Jetson Orin Nano Developer Kit – Unknown Password for Existing jetson User
Hello NVIDIA Support Team,
I have a Jetson Orin Nano Developer Kit that was previously used by another student in our laboratory. The previous user has graduated and did not provide the Ubuntu login password.
The device boots normally and shows the existing Ubuntu login screen. The username is jetson, but we do not know the password for this account.
The current system information is:
  • Device: Jetson Orin Nano Developer Kit
  • L4T: R35.3.1
  • Ubuntu: 20.04
  • CUDA: 11.4
  • Existing username: jetson
I would like to ask for NVIDIA’s officially recommended solution for this situation.
Specifically:
  1. Is there an official method to reset the password for the existing jetson user account when the current password is unknown?
  2. If password recovery is not possible, what is the officially recommended method to restore the Jetson Orin Nano Developer Kit for use by a new user?
  3. Can the device be re-flashed using NVIDIA’s official recovery and flashing procedure?
  4. If re-flashing is recommended, which JetPack/L4T version and procedure should be used for this device?
This is a laboratory development board, and we would like to restore it for continued research and development use.
Please let me know if you need any additional information about the device or current system configuration.
Thank you for your assistance.
Best regards,
Yu-Jie Chiu
For your questions, see the following.
  1. Resetting the existing account password
    If you can log in to another account with sudo privileges, run sudo passwd jetson from that account to set a new password. This uses the administrator account’s credentials and does not require the old jetson password. See the Ubuntu 20.04 password documentation.
  2. Restoring the board for a new user
    A fresh JetPack installation lets you create a new username and password during initial setup. Reimaging the selected storage overwrites its contents, so preserve any required research data first.
  3. Using NVIDIA’s recovery and flashing procedure
    Yes. The developer kit supports host-based flashing through Force Recovery Mode. You can enter this mode using the hardware recovery procedure, without logging in to Ubuntu. Confirm that the host detects the board in recovery mode before flashing.
  4. JetPack/L4T version and procedure
    To reinstall the same Ubuntu 20.04/CUDA 11.4 baseline, use JetPack 5.1.1 / L4T R35.3.1, which supports your developer kit. NVIDIA provides SDK Manager and microSD image installation options, along with the R35.3.1 flashing procedure.
Recommendation: If no administrator account is accessible and a clean installation is acceptable, reinstall JetPack. Please confirm whether the current system is on microSD or NVMe and whether any data must be preserved so we can select the appropriate procedure.
Keep in mind that you can clone the rootfs prior to flashing if you want. Normally you would just flash the Jetson again for a clean install and all of the old content goes away, replaced by the default installation. If you want to keep any content which was on the old filesystem, e.g., a home directory, then cloning first creates a loopback mountable image you could later examine from another machine.
