I am using rel-35.6, and after downloading, the file I got is Jetson_Linux_R35.6.0_aarch64.tbz2. When trying to flash using BalenaEtcher, the .tbz2 file cannot be found. I then extracted the file and compressed it into a ZIP file. I use os windows for flash.
When I opened the ZIP file in BalenaEtcher, it appeared, but an error occurred.
Hi rahmanahmad217,
We officially recommend using Ubuntu 20.04 on a host PC and downloading SDK manager to flash. Based on the log you provided, it appears you may have downloaded an incorrect image.
You can refer to this download center and download the SD Card Image.
