Jetson Orin Nano Devkit: Displayport ceased working w/o resolve by reflash
Hello There,
the Jetson Orin Nano ceased working on the display port. cabling was checked and functional with an other devices. The display remains black after powering the device, acces via ssh is possible. Several reflashes and erases ( line up from JP6 to now latest JP7.2.1) did not resolve the situation.
The investigastions summarizes:
Jetson Orin Nano Super — Intermittent DCE Display RPC Timeout (0x50700457), Display Never Enables
System: P3768-0000 + P3767-0005-super, L4T R39.2.1 (GCID 46758480, built Aug 7 2026), kernel 6.8.12-1021-tegra. All nvidia-l4t-* packages and active bootloader slot confirmed matched at 39.2.1 (nvbootctrl dump-slots-info: clean, both slots normal) — ruled out as a version-skew issue.
Symptom: DP-1 shows status: connected but enabled: disabled. Monitor never lights up.
dmesg pattern:
0x731343  (NV0073_DISPLAY class) → always returns fast NV_ERR_GENERIC (0xffff)
0x50700457 (NV50_DISPLAY class) → intermittently NV_ERR_TIMEOUT (0x65), in clusters, with recovery between clusters
DCE boots cleanly and completes a live version handshake (dcefw:0x4 dcekmd:0x4 err:0x0, DCE_BOOT_DONE) — this isn’t a power/fuse/boot issue. The two RPC classes behave differently, and the system recovers between timeout bursts rather than wedging permanently, which points at a transient internal stall (plausibly during AUX link training or SOR setup) rather than a dead channel.
What we ruled out:
  • Power/fuse — DCE completes a live firmware handshake, impossible if unpowered/disabled
  • BSP/firmware version mismatch — fully aligned, confirmed above
  • Dead physical link — EDID reads succeed cleanly (128 bytes, valid header) over the AUX channel
What we found we can’t see:
  • dce_logs, perf/stats, and perf/events under /sys/kernel/debug/tegra_dce/ are all non-functional on this firmware build (empty even after reproducing the fault; writes to arm perf capture had no effect)
  • tegra-dpaux and tegra-sor drivers are registered but have zero bound device instances
  • No /dev/drm_dp_aux* device exists
  • SOR’s MMIO range doesn’t appear in /proc/iomem at all (unlike dce-fabric, which is explicitly listed)
  • Kernel ftrace tracepoints dpaux_readl/writel and sor_readl/writel were armed and the fault reproduced live — 0/0 entries both times
So on this platform, DCE firmware appears to own the entire AUX/link-training/SOR pipeline exclusively, with no kernel-side visibility at any level — we’ve hit the ceiling of what’s diagnosable from the OS side.
Questions for engineering:
  1. Is a debug/verbose DCE firmware build available that would populate dce_logs/perf on this platform?
  2. Does 0x50700457 perform link training synchronously — could a slow/retrying negotiation with a specific monitor explain this timeout pattern?
  3. Any internal trace facility for DPAUX/SOR activity inside DCE firmware that could be enabled for this build?
    Thanks for supporting.
    Best,
    Daniel
We could not provide you any debug info for DCE firmware.
Please help answer this first
  1. Is this monitor working fine on JP6.x before or not?
  2. Is this issue happened to only specific DP monitor or many kinds?
  3. Please make sure no other adapters are connected between Jetson and your monitor.
so the setup was working fine with JP6.x and it stopped working with JP6.x .
The black screen is with all displays tested (in total 3 2 IIyama, 1 Fujitsu). All of them are known functional with DisplayPort.
That is a direct connection using a Displayport cable, meaning there are no adapters in between. This setup is working with PCs and the matured Jetson Nano.
Is there any typo here? Are you saying that this is not working in jp7.x but working in jp6?
please help dump below log and attach it as file here.
/sys/kernel/debug/tegra_dce/dce_logs# cat logs (need to be as super user)
dce_logs__logs.log (51.7 KB)
So these are the logs
Hi @d_melzer,
I hope you are doing well!
Regarding the DCE logs, I checked the file you attached. It doesn’t seem to be empty, but the content looks binary rather than a readable DCE log. Is this the same behavior you were seeing when you mentioned that dce_logs was not working?
Could you also attach the full dmesg from a boot where the monitor is connected?
sudo dmesg -T > dmesg.txt
It would also be useful to capture what happens during a DP hot-plug. Please boot without the DP cable connected, SSH into the board, run:
sudo dmesg -wT
and then connect the monitor. Please share the messages generated at that point.
One other thing worth checking: with the monitor connected before power-on, do you get any display output before Linux starts, such as the UEFI/NVIDIA boot screen?
Regards,
Oscar Mendez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Hi Oscar,
when it comes to the DCE_LOGS yes that’s what I meant by it’s not working l. If one follows the intstroction of the help file and clear the circular buffer. It stays empty until the display cable is cycled.
In any case the DCE log has a binary content, wondering whether this is intentional.
Attached is the dmesg log of a booting run with attached display. And another run w/o having the display attached and plugged after several second after tracing dmesg was started.
The display just wake up while the cable is getting plugged just to display that there no signal and fall asleep again else it stays black indepdent if the Jetson is power cycled or rebooted. Meaning no Nvidia|UEFI|else bootscreen.
Best,
Daniel
dmesg_boot_w_monitor.log (144.7 KB)
dmesg_boot_wo_monitor.log (110.9 KB)
After checking the DCE log you provided in the previous comment. The decoded DCE log shows repeated DisplayPort link-training failures during clock recovery and channel equalization. In many attempts, the monitor requests the maximum voltage swing, but the link still cannot achieve clock recovery.
Since EDID/AUX communication succeeds and link training occasionally passes, this suggests an unstable DP main-link signal rather than a JetPack 7-specific regression. Please try a known-good short DP cable first. If possible, also swap the Jetson module and carrier board with known-good units to determine whether the issue follows the module or remains with the carrier board/DP connector.
so I got to day my second DevKit from the Office.
The test i did:
  1. Unplug the 1st DevKit ( Defective) and attached 2nd DevKit (healthy) to the Display and cabling, it boot up showed the Nvidia Splash and started Ubuntu normally. init 0 detach cabling ==> Display and Cabling is working.
  2. Disassembled the SOM on Both Dev Kits and mounted the 1st SOM to the 2nd Carrier reattached cabling (Display Power etc,); Jetson booted with no Screen to any time. cycled display, Display woke but got back to Suspend with no Signal, deattached cabling ==> So same situation.
  3. Assembled 2nd SOM on 1st Carrier and est. cabling. Jetson Booted normal with Screen to Ubuntu. ==> Display, Cabling and Carrier are working
    Sum it up the problem is covered on the 1st SOM and it is moving with it.
    Best.
Hi Daniel,
Thank you for performing the cross-swap test. Since the issue follows the first SOM, while the same carrier board, cable, and display work with the second SOM, the problem is localized to the first SOM.
Recommendation: Please proceed with an RMA request for the first developer kit/SOM. Contact your local distributor or reseller first. If needed, you can also contact NVIDIA Customer Care and select Jetson when submitting the request.
Regards.
