Jetson Orin nano devkit USB type-c port cannot communicate with device using USB 3.0
According to the dmesg log the software recognized the device and also must have otherwise succeeded since it saw all partitions. Once it reaches that point it is a matter of seeing if (A) power is an issue, and power changes with usage, or (B) if access to data is available; if access to data is available, then it is a matter of finding out if the filesystem type is supported.
I see this which says the device is there but running at USB2 speeds:
ID 1d6b:0002 Linux Foundation 2.0 root hub
    |__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 480M
Does this command work?
sudo gdisk -l /dev/sda
If this works, then post the result. Also, what is the result of:
lsblk -f /dev/sda
Assuming that works, then the next step is finding out why it reverted to USB2. The possibilities are usually either power delivery being limited, or signal quality. In your previous post with the verbose lsusb (with the -vvv argument), was this from another computer, or was this from the Jetson? If not from the Jetson, then try again from the Jetson and we’ll examine the part which looks at USB3.
Yes this is my USB drive’s content, I flashed it with a Nano Devkit SD card image.
GPT fdisk (gdisk) version 1.0.8
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sda: 61440000 sectors, 29.3 GiB
Model: ProductCode
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 5C316B25-72E3-49E0-8E3D-AA589D426C84
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 61439966
Partitions will be aligned on 2048-sector boundaries
Total free space is 9661 sectors (4.7 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1         3057664        61437951   27.8 GiB    8300  APP
   2            2048          264191   128.0 MiB   8300  A_kernel
   3          264192          265727   768.0 KiB   8300  A_kernel-dtb
   4          266240          331007   31.6 MiB    8300  A_reserved_on_user
   5          331776          593919   128.0 MiB   8300  B_kernel
   6          593920          595455   768.0 KiB   8300  B_kernel-dtb
   7          595968          660735   31.6 MiB    8300  B_reserved_on_user
   8          661504          825343   80.0 MiB    8300  recovery
   9          825344          826367   512.0 KiB   8300  recovery-dtb
  10          827392          958463   64.0 MiB    EF00  esp
  11          958464         1122303   80.0 MiB    8300  recovery_alt
  12         1122304         1123327   512.0 KiB   8300  recovery-dtb_alt
  13         1124352         1255423   64.0 MiB    8300  esp_alt
  14         1255424         2074623   400.0 MiB   8300  UDA
  15         2074624         3056639   479.5 MiB   8300  reserved
$ lsblk -f /dev/sda
NAME FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1
│    ext4   1.0         752d27c0-5370-43a2-9666-6f6c7e937dce
├─sda2
├─sda3
├─sda4
├─sda5
├─sda6
├─sda7
├─sda8
├─sda9
├─sda10
│    vfat   FAT32       4EA2-9257
├─sda11
├─sda12
├─sda13
├─sda14
└─sda15
From Jetson:
$ sudo lsusb -d 346d:5678 -vvv 2>&1 | tee log-verbose.txt
can't get debug descriptor: Resource temporarily unavailable
Bus 001 Device 003: ID 346d:5678 USB Disk 20
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x346d
  idProduct          0x5678
  bcdDevice            3.20
  iManufacturer           1 USB
  iProduct                2 Disk 20
  iSerial                 3 FC047651175E4
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0020
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x0016
  bNumDeviceCaps          2
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000006
      BESL Link Power Management (LPM) Supported
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   3
      Lowest fully-functional device speed is SuperSpeed (5Gbps)
    bU1DevExitLat           0 micro seconds
    bU2DevExitLat           0 micro seconds
Device Status:     0x0000
  (Bus Powered)
The o/s can definitely see and use this device. It also says the device is USB3 (5000M) capable. In theory there is a possibility of this device working.
Is there any way you can try this device over a powered USB3 HUB? If the HUB itself supports USB3, and if the power is provided by the HUB to the device instead of the device drawing power from the Jetson, then any failure to operate at USB3 speed would not be from power requirements. Also, what is the power source of the Jetson? Is it powered with USB? Or is it powered via barrel connector? This makes an enormous difference in what the Jetson’s USB can deliver in terms of power for external USB devices.
Is it possible to check any other USB3 device? Or several? If just one of them works with a speed of at least 5000M (shown in “lsusb -t” or “lsusb -tv”), then you know the device tree is also correct. If the device tree is also correct, and if power is not an issue, then the issue is almost certainly one of signal quality. We know the device itself works due to other computers using it with USB3, but what we don’t know is if power delivery is the issue, and if not power delivery, then we are down to signal quality being the issue.
I have tried several other USB3 devices on the type-c port. I haven’t got one to be detected by the Orin Nano Devkit (0005) as the USB 3 device. The firmware and the OS is flashed using the Nvidia SDK manager on an Ubuntu host machine, it’s quite unlikely to be a device tree issue.
It is powered via a barrel connector. A 19V 4.74A AC/DC Adaptor is used.
I haven’t got a self-powered USB3 Hub by my hand. It takes some time to buy one.
Thanks for your help @linuxdev, I will reply when I got a self-powered USB3 Hub to test.
Sounds good. Aside from testing a powered HUB I don’t know of a lot of guaranteed inexpensive tests to see what is going on. The next step would be to watch what goes on with a hardware USB3 debugger (and we’re talking several thousand dollars for that). I suppose there might be some method of enabling a more verbose log of USB plugin via the NVIDIA driver, but I don’t know what that would be. @WayneWWW do you know of a way to increase the logging verbosity of the moment the controller makes the choice whether to route to USB3 versus legacy controllers?
