HELLO,
I am a beginner in the Jetson orin nano series,I encountered a problem。
I removed the NVIDIA driver through the ‘sudo apt get remove nvidia *’ command, which resulted in the program not running and currently unable to boot。
May I ask why you need such operation?
Drivers on Jetson platforms are directly integrated into the OS(L4T),
and should not be configured with apt, so please re-flash the device to recover it.
OK, thank you, I will try the method you mentioned
