Jetson Orin nano flashing qspi to increase memory
I followed the steps below to flash the QSPI and increase memory, but ran into an error.
[ 0.0795 ] MB1-BCT version: 0.10
[ 0.0796 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0799 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0802 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0804 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0806 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0807 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.0807 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.0807 ]
[ 0.0807 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0807 ] Added Platform Config 9 data with size :- 100
[ 0.0807 ]
[ 0.0807 ] Updating mb1-bct with firmware information
[ 0.0812 ] tegrabct_v2 –chip 0x23 0 –mb1bct mb1_cold_boot_bct_MB1.bct –updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0829 ] tegrahost_v2 –chip 0x23 0 –align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0839 ] tegrahost_v2 –chip 0x23 0 –magicid MBCT –appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0844 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0854 ] tegrasign_v3.py –key None –list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml –pubkeyhash pub_key.key –sha sha512
[ 0.0855 ] Assuming zero filled SBK key
[ 0.0864 ] Warning: pub_key.key is not found
[ 0.0865 ] tegrahost_v2 –chip 0x23 0 –updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0873 ] Generating recovery mb1-bct
[ 0.0878 ] tegrabct_v2 –chip 0x23 0 –mb1bct mb1_bct.cfg –misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb –device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0883 ] MB1-BCT version: 0.10
[ 0.0884 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0887 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0889 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0891 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0893 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0894 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.0894 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.0894 ]
[ 0.0894 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0894 ] Added Platform Config 9 data with size :- 100
[ 0.0894 ]
[ 0.0895 ] Updating mb1-bct with firmware information
[ 0.0899 ] tegrabct_v2 –chip 0x23 0 –mb1bct mb1_bct_MB1.bct –recov –updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0912 ] tegrahost_v2 –chip 0x23 0 –align mb1_bct_MB1_aligned.bct
[ 0.0923 ] tegrahost_v2 –chip 0x23 0 –magicid MBCT –appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.0928 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.0938 ] tegrasign_v3.py –key None –list mb1_bct_MB1_aligned_sigheader.bct_list.xml –pubkeyhash pub_key.key –sha sha512
[ 0.0939 ] Assuming zero filled SBK key
[ 0.0948 ] Warning: pub_key.key is not found
[ 0.0948 ] tegrahost_v2 –chip 0x23 0 –updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0957 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.0957 ] Copying signatures
[ 0.0962 ] tegrahost_v2 –chip 0x23 0 –partitionlayout readinfo_t234_min_prod.xml.bin –updatesig images_list_signed.xml
[ 0.1003 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1005 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1005 ] Boot Rom communication
[ 0.1010 ] tegrarcm_v2 –new_session –chip 0x23 0 –uid –download bct_br br_bct_BR.bct –download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt –download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt –download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1015 ] BR_CID: 0x80012344705DD5032800000012020240
[ 0.1297 ] Sending bct_br
[ 0.1733 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 –new_session –chip 0x23 0 –uid –download bct_br br_bct_BR.bct –download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt –download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt –download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
Any idea on how to resolve this? Is there an alternate method to use?
Config: Ubuntu 20 host, Orin nano devkit (in recovery mode)
did UART show anything during flashing?
Please try these commands:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
If it still does not work, try with a different USB port/USB cable/host, etc.
Changed the autosuspend value.
Tried with a different USB port and cable, same results.
Trying to find another host. Is there any correlation between host OS version and this error? I used an Ubuntu 18.04 host and faced this issue. Should I look for hosts with a different OS version?
it’s a known issue that has been around for quite a while, but haven’t worked out a solution as the root cause is complicated.
18.04 seems to be more stable than 20.04, but it’s not guaranteed. Switching to a different host PC may also work.
Thanks for your reply, will try that.
Could you please tell me a bit more about the root cause?
It’s about instability in USB signals, and it requires some special machines to capture and analyze the signal, so it’s hard for normal users to debug. We are still working on it.
Got it, thanks. Is there a way to increase the memory on the Orin Nano without flashing it? Is something like that possible?
I don’t think so, you do need to flash it to update the bootloader. You won’t be able to touch contents of the bootloader otherwise.
