I’m working with a Jetson Orin Nano SOM on a custom carrier board.
Most of the GPIOs on our board are working as expected. I’m able to monitor and control them using the libgpiod tools (gpioinfo, gpioget, gpioset, gpiomon), and they respond correctly to external signal changes.
The issue is only with the GPIOs in the PCC port. We’ve checked the carrier board schematic and compared it with the NVIDIA pinmux spreadsheet, and the connections look correct. However, these PCC GPIOs don’t show any activity when the input changes, while GPIOs from other ports work without any issues.
I’m trying to understand if there’s something I’m missing specifically for the PCC bank.
Is there anything different about PCC GPIOs compared to the other GPIO banks on Orin Nano?
Do these pins require any additional configuration beyond what other GPIOs need?
If anyone has run into a similar issue, what would you recommend checking to narrow down whether this is a configuration issue or something hardware-related?
I’d appreciate any suggestions or pointers on what to look at next.
We are using JetPack 6.2 (L4T R36.5.0) on the Jetson Orin Nano.
Based on your suggestion, I tested the PCC GPIOs using gpioset.
First, I verified their status using gpioinfo:
line 12: “PCC.00” unused output active-high
line 13: “PCC.01” unused output active-high
line 15: “PCC.03” unused output active-high
Then I manually controlled them using:
gpioset --mode=wait gpiochip1 12=1
gpioset --mode=wait gpiochip1 13=1
gpioset --mode=wait gpiochip1 15=1
While gpioset was running, gpioinfo showed:
line 12: “PCC.00” “gpioset” output active-high [used]
line 13: “PCC.01” “gpioset” output active-high [used]
line 15: “PCC.03” “gpioset” output active-high [used]
This indicates that Linux is able to request and control these GPIOs, and they are not being claimed by another driver such as SPI.
My use case is that these signals are connected to external switches (WiFi Enable, Data Log, and LCD Brightness) on our custom carrier board. The Jetson is expected to detect changes on these GPIOs when the switches are toggled. i have other switches too which are working fine which are not labelled as PCC.
Since the GPIO subsystem appears to be working correctly, I would like to understand whether any additional pinmux or MB1 configuration is required for these pins on a custom carrier board, or if the current configuration should already be sufficient for this use case.
If you want to detect the state change, then you need to configure them as Input rather than Output.
You can simply run gpiomon to monitor their state.
I tested the GPIOs as inputs using gpiomon.
gpiomon successfully acquires the GPIO as an input, and gpioinfo shows:
line 12: “PCC.00” “gpiomon” input active-high [used]
However, no RISING or FALLING edge events are generated when the physical switches are toggled.
gpioget always reads 0 for PCC.00, PCC.01, and PCC.03.
We verified with a multimeter that the signal voltage changes when the switches are toggled.
This behavior is identical on two different boards and is only observed on the PCC GPIOs (PCC.00,PCC.01,PCC.03). Other GPIO-based switches on the board work correctly.
Could you please suggest what should be checked next? Is there any additional pinmux/MB1 configuration or GPIO controller configuration specific to the PCC GPIOs that could prevent the input state from being detected?
Hi Kevin ,
I have configured the GPIO’s as OUTPUT and other fields in the spreadsheet and re-flashed the system, and now the GPIO are working as expected.
