Jetson Orin Nano hangs on recording RTSP to video file
• Hardware Platform (Jetson / GPU): Jetson Orin Nano (8GB) dev kit
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version: 8.5.2
• Issue Type( questions, new requirements, bugs) Bug
  • Pull docker:
    docker pull nvcr.io/nvidia/deepstream:6.3-triton-multiarch
  • Run docker container:
docker run -it \
   --runtime nvidia \
   --gpus all \
   nvcr.io/nvidia/deepstream:6.3-triton-multiarch \
   bash
  • Install packages after running docker container:
    bash /opt/nvidia/deepstream/deepstream/user_additional_install.sh
  • Run Gstreamer pipeline:
mkdir -p outs
gst-launch-1.0 rtspsrc location=rtsp://admin:SQRQIW@192.168.1.22:554 \
    ! decodebin \
    ! nvvideoconvert \
    ! "video/x-raw, format=I420" \
    ! queue \
    ! x264enc \
    ! avimux \
    ! filesink location=outs/record_video.mp4
  • After that, it shows message as in the log.txt file:
    log.txt (1.2 KB)
  • After a while (1 minute), I stop the Gstreamer by Ctrl+C, and check the output video file, but it size is only 0KB
root@1ed96bf64ce7:/opt/nvidia/deepstream/deepstream-6.3# ll outs
total 8
drwxr-xr-x 2 root root 4096 Oct 12 07:35 ./
drwxr-xr-x 1 root root 4096 Oct 12 07:35 ../
-rw-r--r-- 1 root root    0 Oct 12 07:35 record_video.mp4
How to fix it?
Could you chang your pipeline from avimux to qtmux?
@yuweiw Thanks for your reply!
I changed from avimux to qtmux.
Unfortunately, the result is still the same!
log.txt (1.9 KB)
I run the command below on my platform.
gst-launch-1.0 rtspsrc location=rtsp://xxx ! rtph264depay ! h264parse  ! decodebin     ! nvvideoconvert  ! "video/x-raw, format=I420"     ! queue     ! x264enc     ! qtmux     ! filesink location=record_video.mp4
You can try that.
Sorry, it still has error!
log.txt (1.2 KB)
It may be that Gstreamer does not support your rtsp source very well. Could you try to build a rtsp server by refferring the link below: Build rtsp server and try that?
