i am using jetpack 5.11 with ubuntu 20.0.4. Here i connect the mpu6050 sensor to the jetson orin nano scl 5.pin and sda 3.pin.physical connection are all good but i2c is not detecting.can anyone me the solution for this problem
Hi!
Did you try to scan other buses?
I have tried all the buses but It didn’t show any 0x68 address at all
You may need to probe the signal to confirm if the device ack for the i2c command.
Thank you for the reply. My mpu6050 sensor is defective one.
