Hi everyone,
I am planning to permanently install a Jetson Orin Nano in my car, but I want to ensure the power management is handled correctly to avoid any hardware damage or SD card/filesystem corruption.
Here is the behavior I am trying to achieve:
Power On: The Jetson should boot up automatically when the car is started (Ignition/ACC ON).
Power Off (Crucial part): When the car is turned off (Ignition/ACC OFF), the Jetson must not lose power instantly. It needs to stay powered long enough to trigger a graceful software shutdown (e.g., via a script) and completely power off only after the OS has safely halted.
My main concerns are:
Preventing SD card/NVMe corruption from sudden power loss.
Protecting the Jetson board from automotive voltage spikes/drops (especially during engine cranking).
My questions for the community:
Are there any recommended off-the-shelf power management boards, Automotive HATs, or UPS modules designed for this specific use case?
Has anyone implemented delayed boot (e.g., 20 seconds after engine start to avoid crank voltage drop)?
What is the best practice for wiring the ignition sense to trigger the shutdown script safely?
Has anyone successfully deployed a similar setup, and what hardware did you use?
Ideal Scenario
Engine ON → Jetson boots automatically
Engine OFF → Jetson detects ACC off → runs shutdown script → power is cut only after shutdown completes
No SD corruption
No manual interaction required
Any advice, schematic ideas, or product recommendations would be greatly appreciated. Thank you!
