Hi NVIDIA Team,
I am working on a Jetson Orin Nano running JetPack 6.2.1.
My camera module is a 4-lane MIPI CSI-2 camera streaming in GRAY8 format. The board has two CSI connectors, and I have configured the device tree accordingly.
Issue Description
Camera streams successfully when connected to CSI Port-1.
The same camera does not stream when connected to CSI Port-0.
GRAY8 format support has already been added through the required kernel patch, and streaming works correctly on CSI Port-1, so the format patch does not appear to be the issue.
Observed Behavior
When connected to CSI Port-0:
Streaming fails.
Kernel logs show errors such as:
corr_err -
uncorr_err -
capture timeout
When connected to CSI Port-1:
- Streaming works normally.
Platform Information
Board: Jetson Orin Nano
JetPack Version: 6.2.1
Camera Interface: MIPI CSI-2, 4 lanes
Pixel Format: GRAY8
Request
tegra234-camera-custom-cam_V1_2.zip (3.7 KB)
I have attached my DTSI configuration for review. Could someone please review the DTSI and identify any configuration issues related to CSI Port-0?
Please let me know if additional logs or DT nodes are required.
Thank you.
