Hello, I just got a Jetson orin nano developer kit from my team and I am trying to capture and record a video using the ArduCam camera.
When I tested it with my team, the camera worked fine, and so did the video recording. But this morning, I unplugged the original connection wire, which connects the kit and the camera board, and tried to replace it with a longer wire. However, after I inserted the new wire, the working code did not bring up the camera view anymore. Instead, it generated an error, saying No cameras available. I tried with the previous wire, same result.
The attached is the code for checking whether the camera works:
DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=3280,height=2464,format=NV12,framerate=10/1’ ! nvvidconv ! autovideosink -e
I did check dmesg, which is as below:
[ 6.713953] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.720726] gpio-486 (camera-control-output-low): hogged as output/low
For additional information, the error message is as follows:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 No cameras available
WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage: Pipeline construction is invalid, please add queues.
Additional debug info:
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.003749529
Setting pipeline to NULL …
Freeing pipeline …
This has confused me for the whole day, can anyone help please? Thanks.
