Jetson orin nano no video output, error "mode not supported"
I updated to the last version my jetson orin nano with the sdkmanager as a first boot, once the process finished, I connected the jetson to a monitor with the cable (without any adapter) and the monitor is giving me the “mode not supported” error.
I enter through ssh and I ran the command xrandr and the result was
can't open display
What is the status of /var/log/Xorg.0.log?
What was the monitor connection? Is it going through a DP-HDMI adapter? or pure DP ?
thanks for answer, this are the logs of the requested file
[    12.428]
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
[    12.428] Current Operating System: Linux ubuntu 5.15.148-tegra #1 SMP PREEMPT Tue Jan 7 17:14:38 PST 2025 aarch64
[    12.428] Kernel command line: root=PARTUUID=2692c801-eae1-43dd-87a9-a928424376cf rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[    12.428] xorg-server 2:21.1.4-2ubuntu1.7~22.04.12 (For technical support please see http://www.ubuntu.com/support)
[    12.428] Current version of pixman: 0.40.0
[    12.428] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    12.428] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    12.429] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 31 16:00:31 1969
[    12.429] (==) Using config file: "/etc/X11/xorg.conf"
[    12.429] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    12.429] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    12.431] (==) No Layout section.  Using the first Screen section.
[    12.431] (==) No screen section available. Using defaults.
[    12.431] (**) |-->Screen "Default Screen Section" (0)
[    12.431] (**) |   |-->Monitor "<default monitor>"
[    12.431] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    12.431] (**) |   |-->Device "Tegra0"
[    12.431] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    12.431] (==) Automatically adding devices
[    12.431] (==) Automatically enabling devices
[    12.431] (==) Automatically adding GPU devices
[    12.431] (==) Automatically binding GPU devices
[    12.431] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    12.434] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    12.434] 	Entry deleted from font path.
[    12.434] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    12.434] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    12.434] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    12.434] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    12.434] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    12.434] (==) ModulePath set to "/usr/lib/xorg/modules"
[    12.434] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    12.434] (II) Loader magic: 0xaaaad50c2010
[    12.434] (II) Module ABI versions:
[    12.434] 	X.Org ANSI C Emulation: 0.4
[    12.434] 	X.Org Video Driver: 25.2
[    12.434] 	X.Org XInput driver : 24.4
[    12.434] 	X.Org Server Extension : 10.0
[    12.435] (++) using VT number 1
[    12.437] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[    12.438] (II) xfree86: Adding drm device (/dev/dri/card0)
[    12.438] (II) Platform probe for /sys/devices/platform/bus@0/13e00000.host1x/drm/drm/card0
[    12.439] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[    12.441] (II) no primary bus or device found
[    12.441] 	falling back to /sys/devices/platform/bus@0/13e00000.host1x/drm/drm/card0
[    12.441] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[    12.441] (II) "glx" will be loaded by default.
[    12.441] (II) LoadModule: "extmod"
[    12.441] (II) Module "extmod" already built-in
[    12.441] (II) LoadModule: "glx"
[    12.442] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    12.447] (II) Module glx: vendor="X.Org Foundation"
[    12.447] 	compiled for 1.21.1.4, module version = 1.0.0
[    12.447] 	ABI class: X.Org Server Extension, version 10.0
[    12.447] (II) LoadModule: "nvidia"
[    12.447] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    12.455] (II) Module nvidia: vendor="NVIDIA Corporation"
[    12.455] 	compiled for 1.6.99.901, module version = 1.0.0
[    12.455] 	Module class: X.Org Video Driver
[    12.455] (II) NVIDIA dlloader X Driver  540.4.0  Release Build  (bugfix_main)  (buildbrain@mobile-u64-6336-d8000)  Tue Jan  7 17:24:02 PST 2025
[    12.455] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    12.456] (II) systemd-logind: releasing fd for 226:0
[    12.458] (II) Loading sub module "fb"
[    12.458] (II) LoadModule: "fb"
[    12.458] (II) Module "fb" already built-in
[    12.458] (II) Loading sub module "wfb"
[    12.458] (II) LoadModule: "wfb"
[    12.458] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    12.459] (II) Module wfb: vendor="X.Org Foundation"
[    12.459] 	compiled for 1.21.1.4, module version = 1.0.0
[    12.459] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    12.461] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    12.461] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    12.461] (==) NVIDIA(0): RGB weight 888
[    12.461] (==) NVIDIA(0): Default visual is TrueColor
[    12.461] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    12.462] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[    12.462] (**) NVIDIA(0): Enabling 2D acceleration
[    12.462] (II) Loading sub module "glxserver_nvidia"
[    12.462] (II) LoadModule: "glxserver_nvidia"
[    12.462] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[    12.484] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    12.484] 	compiled for 1.6.99.901, module version = 1.0.0
[    12.484] 	Module class: X.Org Server Extension
[    12.484] (II) NVIDIA GLX Module  540.4.0  Release Build  (bugfix_main)  (buildbrain@mobile-u64-6336-d8000)  Tue Jan  7 17:23:04 PST 2025
[    12.485] (II) NVIDIA: The X server supports PRIME Render Offload.
[    13.081] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[    13.081] (--) NVIDIA(0):     DFP-0
[    13.081] (--) NVIDIA(0):     DFP-1
[    13.311] (II) NVIDIA(0): NVIDIA GPU Orin (nvgpu) (GA10B) at SoC (GPU-0)
[    13.312] (--) NVIDIA(0): Memory: 7802780 kBytes
[    13.312] (--) NVIDIA(0): VideoBIOS:
[    13.406] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): connected
[    13.406] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): Internal DisplayPort
[    13.406] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): 2380.0 MHz maximum pixel clock
[    13.410] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    13.410] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    13.411] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    13.465] (==) NVIDIA(0):
[    13.466] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    13.466] (==) NVIDIA(0):     will be used as the requested mode.
[    13.471] (II) NVIDIA(0): Validated MetaModes:
[    13.471] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select"
[    13.471] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[    13.611] (--) NVIDIA(0): DPI set to (157, 161); computed from "UseEdidDpi" X config
[    13.611] (--) NVIDIA(0):     option
[    13.611] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[    13.611] (II) NVIDIA:     access.
[    13.611] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[    13.616] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[    13.616] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    13.616] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    13.616] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    13.616] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    13.616] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    13.616] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    13.616] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    13.616] (II) NVIDIA(0):     Config Options in the README.
[    13.704] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[    13.898] (==) NVIDIA(0): Disabling shared memory pixmaps
[    13.898] (==) NVIDIA(0): Backing store enabled
[    13.898] (==) NVIDIA(0): Silken mouse enabled
[    13.899] (==) NVIDIA(0): DPMS enabled
[    13.899] (II) Loading sub module "dri2"
[    13.899] (II) LoadModule: "dri2"
[    13.899] (II) Module "dri2" already built-in
[    13.899] (II) NVIDIA(0): [DRI2] Setup complete
[    13.899] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    13.900] (II) Initializing extension Generic Event Extension
[    13.900] (II) Initializing extension SHAPE
[    13.901] (II) Initializing extension MIT-SHM
[    13.901] (II) Initializing extension XInputExtension
[    13.901] (II) Initializing extension XTEST
[    13.902] (II) Initializing extension BIG-REQUESTS
[    13.902] (II) Initializing extension SYNC
[    13.902] (II) Initializing extension XKEYBOARD
[    13.902] (II) Initializing extension XC-MISC
[    13.902] (II) Initializing extension SECURITY
[    13.902] (II) Initializing extension XFIXES
[    13.903] (II) Initializing extension RENDER
[    13.903] (II) Initializing extension RANDR
[    13.903] (II) Initializing extension COMPOSITE
[    13.903] (II) Initializing extension DAMAGE
[    13.903] (II) Initializing extension MIT-SCREEN-SAVER
[    13.904] (II) Initializing extension DOUBLE-BUFFER
[    13.904] (II) Initializing extension RECORD
[    13.904] (II) Initializing extension DPMS
[    13.904] (II) Initializing extension Present
[    13.904] (II) Initializing extension DRI3
[    13.904] (II) Initializing extension X-Resource
[    13.905] (II) Initializing extension XVideo
[    13.905] (II) Initializing extension XVideo-MotionCompensation
[    13.905] (II) Initializing extension SELinux
[    13.905] (II) SELinux: Disabled on system
[    13.905] (II) Initializing extension GLX
[    13.905] (II) Indirect GLX disabled.
[    13.905] (II) GLX: Another vendor is already registered for screen 0
[    13.905] (II) Initializing extension XFree86-VidModeExtension
[    13.906] (II) Initializing extension XFree86-DGA
[    13.906] (II) Initializing extension XFree86-DRI
[    13.906] (II) Initializing extension DRI2
[    13.906] (II) Initializing extension NV-GLX
[    13.906] (II) Initializing extension NV-CONTROL
[    13.906] (II) Initializing extension XINERAMA
[    13.969] (II) config/udev: Adding drm device (/dev/dri/card1)
[    13.969] (II) xfree86: Adding drm device (/dev/dri/card1)
[    13.969] (II) Platform probe for /sys/devices/platform/13800000.display/drm/card1
[    13.970] (EE) systemd-logind: failed to take device /dev/dri/card1: Device or resource busy
[    13.970] (II) LoadModule: "modesetting"
[    13.971] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    13.972] (II) Module modesetting: vendor="X.Org Foundation"
[    13.972] 	compiled for 1.21.1.4, module version = 1.21.1
[    13.972] 	Module class: X.Org Video Driver
[    13.972] 	ABI class: X.Org Video Driver, version 25.2
[    13.972] (II) modeset(G0): using drv /dev/dri/card1
[    13.973] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    13.973] (==) modeset(G0): RGB weight 888
[    13.973] (==) modeset(G0): Default visual is TrueColor
[    13.973] (II) Loading sub module "glamoregl"
[    13.973] (II) LoadModule: "glamoregl"
[    13.974] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    13.982] (II) Module glamoregl: vendor="X.Org Foundation"
[    13.982] 	compiled for 1.21.1.4, module version = 1.0.1
[    13.982] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    14.036] (II) modeset(G0): glamor X acceleration enabled on NVIDIA Tegra Orin (nvgpu)/integrated
[    14.036] (II) modeset(G0): glamor initialized
[    14.036] (II) modeset(G0): Output DP-1-1 has no monitor section
[    14.037] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    14.037] (==) modeset(G0): DPI set to (96, 96)
[    14.037] (II) Loading sub module "fb"
[    14.037] (II) LoadModule: "fb"
[    14.037] (II) Module "fb" already built-in
[    14.037] (EE) modeset(G0): drmSetMaster failed: Device or resource busy
[    14.039] (II) UnloadModule: "modesetting"
[    14.039] (II) UnloadSubModule: "glamoregl"
[    14.039] (II) Unloading glamoregl
[    14.039] xf86: found device 1
[    14.041] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=3 (/dev/input/event1)
[    14.041] (II) No input driver specified, ignoring this device.
[    14.041] (II) This device may have been added with another device file.
[    14.041] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=7 (/dev/input/event2)
[    14.042] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=8 (/dev/input/event3)
[    14.042] (II) No input driver specified, ignoring this device.
[    14.042] (II) This device may have been added with another device file.
[    14.043] (II) config/udev: Adding input device NVIDIA Jetson Orin Nano HDA HDMI/DP,pcm=9 (/dev/input/event4)
[    14.043] (II) No input driver specified, ignoring this device.
[    14.043] (II) This device may have been added with another device file.
[    14.043] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[    14.043] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[    14.043] (II) LoadModule: "libinput"
[    14.044] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    14.048] (II) Module libinput: vendor="X.Org Foundation"
[    14.048] 	compiled for 1.20.14, module version = 1.2.1
[    14.048] 	Module class: X.Org XInput Driver
[    14.048] 	ABI class: X.Org XInput driver, version 24.1
[    14.048] (II) Using input driver 'libinput' for 'gpio-keys'
[    14.049] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 46 paused 0
[    14.049] (**) gpio-keys: always reports core events
[    14.049] (**) Option "Device" "/dev/input/event0"
[    14.057] (II) event0  - gpio-keys: is tagged by udev as: Keyboard
[    14.057] (II) event0  - gpio-keys: device is a keyboard
[    14.057] (II) event0  - gpio-keys: device removed
[    14.057] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input0/event0"
[    14.057] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 6)
[    14.057] (**) Option "xkb_model" "pc105"
[    14.057] (**) Option "xkb_layout" "us"
[    14.058] (II) event0  - gpio-keys: is tagged by udev as: Keyboard
[    14.059] (II) event0  - gpio-keys: device is a keyboard
[    14.069] (II) config/udev: removing GPU device /sys/devices/platform/13800000.display/drm/card1 /dev/dri/card1
[    14.069] (II) config/udev: Adding drm device (/dev/dri/card1)
[    14.069] (II) xfree86: Adding drm device (/dev/dri/card1)
[    14.069] (II) Platform probe for /sys/devices/platform/13800000.display/drm/card1
[    14.070] (EE) systemd-logind: failed to take device /dev/dri/card1: Device or resource busy
[    14.070] (II) LoadModule: "modesetting"
[    14.071] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    14.071] (II) Module modesetting: vendor="X.Org Foundation"
[    14.071] 	compiled for 1.21.1.4, module version = 1.21.1
[    14.071] 	Module class: X.Org Video Driver
[    14.071] 	ABI class: X.Org Video Driver, version 25.2
[    14.071] (II) UnloadModule: "modesetting"
[    14.071] (II) Unloading modesetting
[    14.071] (II) Failed to load module "modesetting" (already loaded, 0)
[    14.071] (II) modeset(G0): using drv /dev/dri/card1
[    14.072] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    14.072] (==) modeset(G0): RGB weight 888
[    14.072] (==) modeset(G0): Default visual is TrueColor
[    14.072] (II) Loading sub module "glamoregl"
[    14.072] (II) LoadModule: "glamoregl"
[    14.073] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    14.079] (II) Module glamoregl: vendor="X.Org Foundation"
[    14.079] 	compiled for 1.21.1.4, module version = 1.0.1
[    14.079] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    14.082] (II) modeset(G0): glamor X acceleration enabled on NVIDIA Tegra Orin (nvgpu)/integrated
[    14.082] (II) modeset(G0): glamor initialized
[    14.082] (II) modeset(G0): Output DP-1-1 has no monitor section
[    14.082] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    14.082] (==) modeset(G0): DPI set to (96, 96)
[    14.082] (II) Loading sub module "fb"
[    14.082] (II) LoadModule: "fb"
[    14.082] (II) Module "fb" already built-in
[    14.082] (EE) modeset(G0): drmSetMaster failed: Device or resource busy
[    14.083] (II) UnloadModule: "modesetting"
[    14.083] (II) UnloadSubModule: "glamoregl"
[    14.083] (II) Unloading glamoregl
[    14.083] xf86: found device 1
[    14.817] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): connected
[    14.817] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): Internal DisplayPort
[    14.818] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): 2380.0 MHz maximum pixel clock
[    14.821] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    14.821] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    14.821] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    16.781] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): connected
[    16.782] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): Internal DisplayPort
[    16.782] (--) NVIDIA(GPU-0): Samsung Odyssey G70B (DFP-0): 2380.0 MHz maximum pixel clock
[    16.785] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    16.785] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    16.785] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
and I am using pure dp cable
I don’t see any error from the log itself.
Did you “export DISPLAY=:0” before you run xrandr?
Also, which Jetpack version is that?
I tried again with export DISPLAY=:0 and then sudo xrandr and the answer was
Authorization required, but no authorization protocol specified
Can't open display :0
I installed Jetpack 6.2
Is same monitor able to work with rel-35/jetpack5.1.5?
I didn’t tried since the first step on the setting of Orin nano is to update it
How was your method to flash this board in the first time?
hi, I connected the device to an unbuntu machine and run the sdk manager. Following the instructions of
Then could you use sdkanager to flash your board to jetpack5 and see if that monitor can work?
I could not flash on jetpack5 since the sdk manager didn’t let me (see screenshot), I formatted to the v6.0 (I was in 6.2) and the same issue
@WayneWWW any other option to fix it ? or any other test that you need for this ?
Do you have any old Ubuntu host on your side that can flash Jetpack5?
The reason that sdkm didn’t let you flash is because ubuntu version not supported.
wich version should be? I am running on 22.04, sadly I don’t have another computer to try
Your screenshot already provided the answer.
but question, what would mean if I have video with the version 5.1.5, the video should work with any jetpack version right ?
From such remote debug, I can only suggest you to cross check. If jetpack5 can have that Samsung monitor work, I can only label this kind of model and maybe test in future once we get same monitor on our side.
Thus, if you insist on using jetpack6, I could only suggest you try other monitors.
Also, the purpose of trying rel-35 is to test if the hardware has any problem or not. If none of the monitor ever light up, then it has chance to be a hardware problem.
BTW, when you run xrandr, please do not run it as root. It won’t work. I don’t know if you did that way or not.
ok, for the monitor, I took my wife monitor ( a DELL) and it giving signal, thanks for the support ( I feel so dumb about it )
Ok. So the conclusion here is Jetpack6.2 + Orin Nano DP port somehow cannot output Samsung Odyssey G70B.
