Jetson Orin Nano not powering up but LED is on
Hello team,
I have been using jetson orin nano for quite sometime. I have installed jetpack 5.1.3. Initially, it was working fine but all of a sudden it stopped powering on. So, I flashed it and it started working again. After few months, it happened again. what could be the issue? I have been integrating it to a outdoor robot and afraid that this may occur again. Could you please let me know where the issue is?
Not possible to know what is the cause. You should dump the log when error happened.
basically, the display is also not been turning on when this happened so no opportunity to collect any log data.
Yes, I know you cannot check from monitor…
You could learn to dump log from serial console. The log will be shown on another host PC…
BTW, unable to connect any usb deice too. there is no signal coming out from usb ports
In case you don’t know, the serial console log is based on UART and no matter what situation your board is, it shall be able to print some logs…
If there is no log, only 2 possible reasons.
  1. The board is hardware defected
  2. The serial console setup is wrong.
Okay, I’ll do it if it occurs again.
