I am currently designing a custom carrier board for Jetson Orin Nano / Orin NX and have a question regarding the I²C electrical specifications.
Based on the discussion in the following forum post:
For the I2C[1,0] pins, the specifications appear to be:
VIL = 1.8 V × 0.2 = 0.36 V
VOL = 1.8 V × 0.3 = 0.54 V
When the I²C bus is operating at 3.3 V, the Orin VOL requirement does not seem to be an issue, since:
0.54 V < 0.99 V (3.3 V × 0.3)
Additionally, as mentioned in other forum posts, the VOL can be tuned if necessary.
However, the VIL specification appears to be more critical when interfacing with a 3.3 V I²C device.
Some external I²C devices specify a VOL of up to 0.4 V, which would be higher than Orin’s VIL threshold of 0.36 V. In this case, when the external device pulls the bus low, there seems to be a potential risk that Orin may not reliably recognize the LOW level.
Could you please help clarify whether:
My understanding of the VIL / VOL interaction in this scenario is incorrect, or
This is a known and expected limitation when connecting Jetson Orin Nano / NX to certain 3.3 V I²C devices?
Any guidance on recommended design practices (for example, level shifting, pull-up tuning, or register configuration) would be greatly appreciated.
This topic is sometimes referred to as a datasheet/paper violation. In practice with the actual hardware it is usually not an issue.
To mitigate, you could add a provision for a level shifter that has a VOL max below 0.36V and allows VDDA=VDDB=3.3V. It would not be level shifting in the traditional sense (e.g. 1.8V on one side to 3.3V on the other). It would have 3.3V on both sides and act more as a re-driver that is compatible with Orin’s VIL. By default you could have series resistor options to directly connect your board’s I2C bus to Orin’s I2C[1:0] or re-route the signals through the level shifter.
So to begin with you would directly connect your board’s I2C bus to Orin and characterize your devices with VOL=0.4V. If they do only reach ~0.4V, you can try the level shifter.
