Jetson Orin Nano software encoder is not working for me
• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 6.4
**• JetPack Version (valid for Jetson only)**6.0
• TensorRT Version8.6.2.3
**• Issue Type( questions, new requirements, bugs)**x264enc not working for me??
Hi, I’m very new but I’ve set up my Orin Nano and have successfully run the deepstream-app -c with the source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt and it runs as described but as soon as I enable the sink0 for a file output I get a small video file with unreadable file or if I enable sink1 for an rtsp stream output I can open the stream with vlc but the output is just green and of course the logs are giving me the ‘gstnvtracker: Unable to acquire a user meta buffer. Try increasing user-meta-pool-size’ message.
And when I run this:
gst-launch-1.0 filesrc location=sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! ‘video/x-raw(memory:NVMM), format=NV12’ ! nvvidconv ! video/x-raw, format=I420 ! x264enc ! h264parse ! filesink location=transcode-test-01.mp4 -e
I get a 11mb file that doesn’t play. The ubuntu media player says it’s an empty file and vlc just doesn’t play and doesn’t give a message.
I have tried to find a solution in the forums but I haven’t found what I missed.
I could use a little guidance please.
EDIT** I get the identical behaviour when I run the deepstream:6.4-samples-multiarch docker container as well.
This is a bug in DS-6.4 and there is currently no workaround.
You can only roll back to DS-6.3 or wait for the next version
