Jetson Orin Nano Super Dev Kit - Boot hangs after Jetpack 7.2 Installation on NVMe SSD, installer skips username/password setup
(Quick note: I used AI to help structure this post clearly, as I’m relatively new to this and English isn’t my first language. Happy to clarify anything in my own words if needed.)
Hardware: Jetson Orin Nano Super Developer Kit, KKSB case, SanDisk SSD Plus 250GB NVMe SSD (M.2 2280, PCIe Gen 3.0)
JetPack version: 7.2 (Jetson Linux 39.2), installed via USB stick installer (ISO method, flashed with Rufus)
Issue 1 – Installer skips setup screens: When selecting “Install on NVMe,” the installation starts immediately without prompting for language, network configuration, or username/password setup. It goes straight to “Finished installation and reboot.” This has happened consistently across multiple fresh install attempts.
Issue 2 – Boot hangs after installation: After installation completes and the board reboots, the NVIDIA boot logo appears briefly, then the screen goes black/gray with only a blinking cursor in the top-left corner. No response to keyboard/mouse on the main display. Sometimes Ctrl+Alt+F2 reaches a “localhost login:” prompt, sometimes not (seems inconsistent).
Issue 3 – Login fails: At the “localhost login:” prompt (when reachable), none of the following credential combinations work: nvidia/nvidia, ubuntu/ubuntu, ubuntu/empty, root/empty. Additional observation: Board became noticeably warm during one of the hung boot attempts.
What I’ve already tried:
  • Multiple clean installs (first attempted on a microSD card, same hang pattern occurred there too, then switched to NVMe SSD)
- Re-flashed USB installer stick multiple times with Rufus
- Checked UEFI Boot Manager – both SSD and USB stick are correctly detected
- Tried common recovery credential combinations without success
I’d really appreciate any pointers on:
  1. Why the installer might skip the username/password setup screen entirely — is this expected behavior for JetPack 7.2, or a sign something’s wrong with my install media?
  2. Whether there’s a Jetson-specific way to reset credentials or reach recovery mode, since no GRUB menu appears during boot
  3. Whether a DRAM-less SSD like the SanDisk SSD Plus could realistically cause this kind of behavior, or if I should rule that out and look elsewhere
I’m still fairly new to Jetson/embedded Linux, so if I’m missing something obvious, please feel free to point it out — happy to provide more logs, photos, or details.
Please use the BalenaEtcher to install ISO and check whether the issue exist.
Hi, thanks for the response.
I just tried installing with BalenaEtcher instead of Rufus, but got the same result. After booting from the USB stick and selecting “Install on NVMe,” the installation starts immediately with no language selection, no network configuration, and no username/password setup screen. It goes straight to installation progress and then to “Finished installation and reboot.”
After reboot, the board hangs on a black/gray screen with a static (non-blinking) cursor in the top-left corner, same as with the Rufus-flashed installer.
So the installer tool doesn’t seem to be the cause. Any other ideas what could be causing this?
We can successfully install 7.2 on orin nano super with NVMe using iso .
log.txt (401.1 KB)
Please make sure you connect to the display when install iso.
Also please provide the serial console log for us to review if issue exists.
I’m facing the exact same issue.
I tried to install from different USB Sticks on SD Card and on nvme. But both have the same result as described here above. In the latest jetpack 6.2, I disabled the graphical UI could it have an impact?
I got the same issue! I used BalenaEtcher as well.
Hi @mseifert03 ,
Any update from your side?
I succeeded to install it using the SDKManager (using a Windows computer).
Hi, yes I got it working.
Turns out I needed to actively press Y on the QSPI firmware capsule update prompt (the one with the 30-second countdown at the start of the install). I’d seen it every time but assumed it would resolve itself automatically if I just let it run, so I never confirmed it manually. Once I pressed Y instead of letting it time out, the setup screens (language, network, username/password) finally showed up properly, and the install completed without issues.
Also cleaned up the NVMe SSD and USB stick with diskpart beforehand (they had accumulated a bunch of leftover partitions from the failed attempts), which probably helped too.
Thank your for your feedback.
Please mark the solution so we could close the topics.
