I am using a Jetson Orin Nano Super Developer Kit and facing an intermittent “system throttled due to over-current” issue while running my AI application.
The issue occurs even when using 25W and MAXN_SUPER modes. Interestingly, sometimes switching back to 15W allows the application to run normally, but at other times the system still gets throttled.
I also see an intermittent nvpmodel.service failure:
systemctl status nvpmodel.service
× nvpmodel.service - nvpmodel service
Loaded: loaded (/etc/systemd/system/nvpmodel.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Tue 2026-09-22 18:49:46 IST; 2min 33s ago
Process: 2228 ExecStart=/etc/systemd/nvpmodel.sh (code=exited, status=234)
Main PID: 2228 (code=exited, status=234)
CPU: 16ms
Sep 22 18:49:46 jetson-orin-nano systemd[1]: Starting nvpmodel.service - nvpmodel service...
Sep 22 18:49:46 jetson-orin-nano nvpmodel.sh[2234]: NVPM WARN: Golden image context is already created
Sep 22 18:49:46 jetson-orin-nano nvpmodel.sh[2234]: NVPM WARN: Reboot required for changing to this power mode: 0
Sep 22 18:49:46 jetson-orin-nano nvpmodel.sh[2234]: NVPM WARN: DO YOU WANT TO REBOOT NOW? enter YES/yes to confirm:
Sep 22 18:49:46 jetson-orin-nano nvpmodel.sh[2234]: NVPM ERROR: bad input!
Sep 22 18:49:46 jetson-orin-nano nvpmodel.sh[2234]: NVPM ERROR: optMask is 2, no request for power mode
Sep 22 18:49:46 jetson-orin-nano systemd[1]: nvpmodel.service: Main process exited, code=exited, status=234/n/a
Sep 22 18:49:46 jetson-orin-nano systemd[1]: nvpmodel.service: Failed with result 'exit-code'.
Sep 22 18:49:46 jetson-orin-nano systemd[1]: Failed to start nvpmodel.service - nvpmodel service.
However, jetson_clocks --show sometimes reports:
SOC family:tegra234 Machine:NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
Online CPUs: 0-5, Offline CPUs:
cpu0: Governor=schedutil MinFreq=729600 MaxFreq=1728000 CurrentFreq=1497600 IdleStates: WFI=1 c7=1
cpu1: Governor=schedutil MinFreq=729600 MaxFreq=1728000 CurrentFreq=1344000 IdleStates: WFI=1 c7=1
cpu2: Governor=schedutil MinFreq=729600 MaxFreq=1728000 CurrentFreq=1267200 IdleStates: WFI=1 c7=1
cpu3: Governor=schedutil MinFreq=729600 MaxFreq=1728000 CurrentFreq=1420800 IdleStates: WFI=1 c7=1
cpu4: Governor=schedutil MinFreq=729600 MaxFreq=1728000 CurrentFreq=729600 IdleStates: WFI=1 c7=1
cpu5: Governor=schedutil MinFreq=729600 MaxFreq=1728000 CurrentFreq=729600 IdleStates: WFI=1 c7=1
GPU MinFreq=306000000 MaxFreq=1020000000 CurrentFreq=1020000000
Active GPU TPCs: 8
EMC MinFreq=204000000 MaxFreq=3199000000 CurrentFreq=2133000000
FAN Dynamic Speed Control=nvfancontrol hwmon0_pwm1=80
FAN Dynamic Speed Control=nvfancontrol hwmon0_pwm1_enable=1
NV Power Mode: 15W
Sometimes the AI application runs normally with the same configuration, and sometimes it gets throttled.
Questions:
- What could cause this intermittent over-current throttling?
- Is the
nvpmodel.servicefailure related to the power mode not being applied correctly? - Is
GPU CurrentFreq=1020 MHzexpected in 15W mode? - What diagnostics can I use to identify the actual source of the over-current condition?
- How to solve the issue?
