Jetson Orin Nano USB Target Flashing method crashes
Subject: JetPack 7.2.1 ISO installer fails during Curtin/Subiquity storage setup due to missing ‘bcache’ module
Description:
When attempting to use the JetPack 7.2.1 (Jetson Linux 39.2.1) unified ISO installer, the deployment crashes during the storage partitioning configuration phase because the kernel module ‘bcache’ cannot be located.
Environment:
  • Target Hardware: Jetson Orin Nano / NX Developer Kit
  • JetPack Version: 7.2.1 (Jetson Linux r39.2.1)
  • Kernel Version: 6.8.12-1021-tegra
Error Log Snippet:
finish: CMD-INSTALL/stage-partitioning/builtin/cmd-block-meta: FAIL: curtin command block-meta
Traceback: …
curtin.util.ProcessExecutionError: Unexpected error while running command.
Command: [‘modprobe’, ‘–use-blacklist’, ‘bcache’]
Exit code: 1
Stderr: modprobe: FATAL: Module bcache not found in directory /lib/modules/6.8.12-1021-tegra
Hello @jesusbravo38!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Hi jesusbravo38,
This looks like an ISO installer issue.
During the interactive storage/partitioning flow, Curtin/Subiquity may try to load the bcache module, but the current installer kernel does not include it, which causes the installation to fail at the partitioning stage.
As a workaround, it is better to avoid the interactive/manual storage UI and use a non-interactive or explicitly targeted install flow instead.
