Jetson Orin Nano Won't Power On After CAN Bus Wiring Burned – Need Help Identifying a Damaged Component
Hi everyone,
I was previously using my Jetson Orin Nano without any issues. However, the GND wire connecting the Jetson to an SN65HVD230 CAN transceiver suddenly burned. After this incident, my Jetson Orin Nano would no longer power on, and I noticed a burning smell.
I inspected the carrier board but couldn’t find any visibly damaged components. However, after inspecting the Jetson Orin Nano SOM (System-on-Module), I found a component that appeared to be burned.
I also tried removing the SOM and powering on the carrier board by itself. I measured 5V on the 5V power rail, but the 3.3V rail was not present.
Is this normal behavior when the SOM is disconnected, or could it indicate a problem with the carrier board?
I have a few additional questions:
  1. Can anyone help identify the burned component on the SOM? Is it a diode, a resistor, or another type of component?
  2. Does anyone know its package size and specifications?
  3. Is it possible to replace the damaged component, or could the SOM have suffered more extensive damage?
  4. What troubleshooting steps would you recommend before attempting any repairs?
I have attached photos of the damaged component for reference.
Hello @wahyudwiahmadi793!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Thank you for reaching out and sorry to hear about the damage to your Jetson Orin Nano.
Unfortunately, the internal module design and component details are not publicly available, so we are unable to identify the specific damaged component from the photo.
Additionally, with an overcurrent event like this, it is not possible to determine whether the damage is limited to the visibly burned component or if there is additional hidden damage to other internal components.
