We’re deploying Jetson Orin in sealed enclosures where only Ethernet and RS-232 (DB9) are externally accessible, no USB-C Console (ttyTCU0). We need remote kernel console for production diagnostics but both paths are blocked:
1. RS-232 (ttyTHS1) can’t be a kernel console — `serial-tegra` has `.cons = NULL` in its `uart_driver`. `console=ttyTHS1,115200` is silently ignored. The 8250_tegra fallback produces garbled output because it doesn’t call `clk_set_rate()` (Tegra234 UARTs require active clock management).
2. netconsole is disabled — `CONFIG_NETCONSOLE` is `not set`, `CONFIG_NETPOLL` absent. Can’t build as OOT module since netpoll is core networking code. Full kernel rebuild required.
What we tried
- `console=ttyTHS1,115200` is ignored since there is no `struct console` in serial-tegra
- `nvidia,tegra20-uart` DTB + 8250_tegra gives us garbled output at all baud rates (clock mismatch!?)
- `modprobe netconsole` results in module not found
- OOT build of netconsole.ko is impossible (needs CONFIG_NETPOLL built-in) |
Questions
1. Why is `CONFIG_NETCONSOLE` disabled in stock L4T? It’s a standard kernel feature with zero side effects when unused. A one-line defconfig change would unblock remote diagnostics for all Jetson users.
2. Would NVIDIA consider enabling it in a future release?
3. Is there a reason `serial-tegra` omits `struct console`? The driver already has `tegra_uart_write()`, LSR polling, and `clk_set_rate()` in `tegra_set_baudrate()` — adding polled console output would be ~60 LOC.
4. Is there any supported path to remote kernel console without a custom build?
