Hi All,
I have a custom base board and using a jetson orin nx 16GB module. The SOM ethernet is connected directly to the phy port of the ksz9477 switch and the SPI to control the switch.
I also have other devices connected to the other phy ports and I´m not using the RGMII and SGMII ports.
I´m currently having issues with the dsa driver (dsa2.c) and I could track the problem down to the dsa_port_parse_of function.
if (ethernet) {
struct net_device *master;
master = of_find_net_device_by_node(ethernet);
of_node_put(ethernet);
if (!master){
return -EPROBE_DEFER;
return dsa_port_parse_cpu(dp, master);
Where this function is returning EPROBE_DEFER.
I´m editing tegra234-p3768-0000-a0.dtsi and added the following to this file:
eth1: pcie@140a0000 {// C8 - Ethernet
status = “okay”;
//nvidia,pex-wake-gpios = <&tegra_main_gpio TEGRA234_MAIN_GPIO(L, 2) GPIO_ACTIVE_LOW>;
spi@3210000{ /* SPI1 in 40 pin conn */
status = "okay";
ksz9477@0{
compatible = "microchip,ksz9477";
reg = <0x0>;
reset-gpios = <&tegra_aon_gpio TEGRA234_AON_GPIO(CC, 2) GPIO_ACTIVE_HIGH>;
spi-max-frequency = <1000000>;
spi-cpha;
spi-cpol;
status = "okay";
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x10>;
nvidia,tx-clk-tap-delay = <0x0>;
ports{
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
label = "cpu";
ethernet = <ð1>;
phy-mode = "rgmii-txid";
fixed-link {
speed = <1000>;
full-duplex;
pause;
port@1 {
reg = <1>;
label = "lan2";
port@2 {
reg = <2>;
label = "lan3";
port@3 {
reg = <3>;
label = "lan4";
port@4 {
reg = <4>;
label = "lan5";
Could you please help me check what could be going wrong?
Best Regards
Daniel
