Jetson Orin NX 16GB no longer boots – flashing consistently fails with USB write timeout while sending blob
NVIDIA Customer Care has asked me to post this case here so that the Jetson specialists can technically evaluate whether my Jetson Orin NX 16GB module has suffered a hardware failure.
System
  • NVIDIA Jetson Orin NX 16GB
  • Yahboom carrier/system
  • JetPack 6.2 / L4T R36.4.4
  • Board detected by TegraFlash as:
    • Board ID: 3767
    • Version: 303
    • SKU: 0000
    • Revision: C.1
  • Tegra234
  • System was previously working normally.
Original problem
The system suddenly stopped booting.
When powered on, the cooling fan repeatedly starts and stops, but the Jetson does not complete the normal boot process.
I initially suspected the SSD, but the problem appears to be independent of the operating-system drive. I have also been troubleshooting the system with Yahboom technical support and followed their recommendation to re-flash the bootloader.
Force Recovery Mode works
The module can successfully enter Force Recovery Mode and is detected by the host as:
0955:7323 NVIDIA Corp. APX
This detection is stable before starting the flashing procedure.
USB autosuspend was also disabled:
/sys/module/usbcore/parameters/autosuspend = -1
TegraFlash communication appears to work initially
The flashing procedure successfully:
  • detects the Tegra234 device;
  • reads the ECID;
  • communicates with BootROM;
  • sends BCT, MB1, PSC and MB2 applet;
  • starts the MB2 applet successfully;
  • reads the device fuses;
  • retrieves chip information;
  • reads the module EEPROM;
  • identifies the board correctly;
  • generates the memory BCT and recovery images.
Examples from the log:
Boot Rom communication completed
MB2 Applet version 01.00.0000
Fuse read successful
Saved platform info in .../cvm.bin
Board ID(3767) version(303) sku(0000) revision(C.1)
The reported chip information includes:
Chip sku: 0xd3
Chip Sample: prod
Failure during flashing
The procedure subsequently reaches:
Sending membct and RCM blob
and then:
Sending bct_mem
Sending blob
Immediately afterwards it consistently fails with:
ERROR: might be timeout in USB write.
Error: Return value 3
Failed flashing generic.
The relevant TegraFlash command at the failure point is:
tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
The generated blob is approximately 22.6 MB.
What I would like to determine
Since the module remains responsive enough to enter Recovery Mode, run MB2, read fuses and EEPROM, but the flashing process repeatedly fails during the blob transfer, I would appreciate your help determining whether this behaviour is consistent with:
  1. a hardware failure of the Jetson Orin NX module;
  2. an issue with the module’s memory/storage/boot subsystem;
  3. a carrier-board or power-delivery issue;
  4. a USB communication issue;
  5. the flashing environment / VM;
  6. or another known Jetson Orin NX failure mode.
NVIDIA Customer Care specifically asked me to obtain a technical assessment here before they review the warranty/RMA options.
I can upload the complete logs and diagnostic files, including:
  • 01_recovery_usb_identity.txt
  • 02_recovery_before_second_flash.txt
  • 03_super_boot_second_attempt.log
  • 06_second_flash_error_summary.txt
  • 07_second_flash_last_100_lines.txt
I can also perform any additional tests you recommend.
In particular, I would appreciate confirmation of whether there is a test that can distinguish conclusively between a USB/host/carrier issue and a module-level hardware failure.
Thank you very much for your help.
03_super_boot_second_attempt.log (119.3 KB)
Please provide the serial console log for us to review.
Thank you for your instructions.
I will need a few days before I can provide the serial console log you have requested. I first need to purchase the appropriate USB-to-UART cable, receive it, and then follow the technical procedure required to connect to the debug UART and capture the boot log correctly.
I will, of course, make the effort to perform these tests and provide you with the requested information. However, I would also like to formally raise a concern regarding this support process.
In my view, it is not reasonable to expect a customer — who does not necessarily have to be an embedded systems or Jetson hardware specialist — to carry out this level of hardware diagnosis and Root Cause Analysis themselves. The procedure involves identifying debug headers, connecting UART interfaces, handling the Jetson module and carrier board, configuring serial communications, performing recovery-mode tests, and potentially mounting and dismounting hardware several times.
This effectively transfers a significant part of the technical diagnostic work normally associated with a technical support or repair service to the customer.
More importantly, I believe this approach can actually be counterproductive for NVIDIA. A customer without sufficient hardware experience could accidentally damage a module, carrier board, connector or other component while performing the requested RCA procedure. In that situation, a product that may initially have had a limited or recoverable fault could potentially suffer additional damage during the diagnostic process.
In my particular case I am technically able to follow the procedure, although it requires additional equipment, time and effort. However, I do not believe this should be assumed for every Jetson customer.
I therefore think NVIDIA should ideally provide either:
  • an authorised technical service where the module can be professionally diagnosed, or
  • the possibility of sending the module directly to NVIDIA or an authorised partner for hardware evaluation when a module-level failure is suspected.
In any case, I will proceed with the requested UART diagnostic and send you the results as soon as I have received the required cable and completed the procedure correctly.
Thank you for your understanding and support.
Best regards,
Miguel Ángel Rodríguez López
Someone replied to your post.
| DavidDDD Moderator
August 24 |
JetsonHacks – 19 Apr 19
Jetson Nano & NX Style - Serial Debug Console - JetsonHacks
The Serial Debug Console is the most basic way to be able to interface with your Jetson Nano & NX Style Developer Kit. All it takes is a magic wire!
Est. reading time: 7 minutes
Hi, Miguel
The log suggests that you’re flashing from inside a virtual machine:
yahboom@VM:~/jetpack_6.2/Linux_for_Tegra
That matters here, because the failure looks like a USB transport drop rather than a module fault.
[ 11.7202 ] ERROR: might be timeout in USB write.
If that’s the case, could you retry the flash from an Ubuntu host (not a VM)?
I also recommend you opening a second terminal and running this command: sudo dmesg --follow and make sure the USB device is detected as high-speed.
Daniel Chaves
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
This is not any meaningful log. It does not mean you have USB issue. Any kind of flash failure could lead to this print.
That is why serial log is needed.
But indeed a non VM host machine is worthy trying.
As requested, I have now completed the UART serial-console diagnostic and attached the full PuTTY log to this email.
To perform the test, I purchased the required 3.3 V USB-to-UART adapter and captured the serial output through the J14 debug header while the problematic Jetson Orin NX 16GB module was installed on an official NVIDIA P3768 carrier board.
The module was started in normal cold-boot mode, without using the Force Recovery jumper.
The attached log shows the following:
  • MB1 starts correctly and identifies the Tegra 234 production silicon.
  • The Macronix 64 MB QSPI flash is detected and initialized successfully.
  • MEM-BCT-0 is read successfully from storage.
  • Both the MEM-BCT header and binary integrity checks complete successfully.
  • MB1 then reaches the SDRAM initialization stage.
  • The log consistently reaches:
    • Task: SDRAM init
    • MemoryType: 4 MemBctRevision: 2
    • MSS CAR: Init PLLM
    • MSS CAR: Init PLLHUB
    • Encryption: MTS: en, TX: en, VPR: en, GSC: en
  • Immediately after this point, the module resets and starts another cold-boot cycle.
  • Subsequent cycles report rst_source: 0x13.
  • This sequence repeats continuously.
  • The module never reaches successful SDRAM initialization, MB2, UEFI, the Linux kernel, or the operating system.
The recorded temperatures remain within a normal range during the test, so the behaviour does not appear to be caused by overheating.
This result also needs to be considered together with the previous diagnostic evidence:
  • The failure was originally observed while the module was installed on the Yahboom carrier board.
  • Another compatible Jetson module worked correctly on that carrier board.
  • The same failure has now been reproduced with the problematic module installed on an official NVIDIA P3768 carrier board.
  • The module is detected correctly in Force Recovery mode as an NVIDIA APX device.
  • Previous flashing attempts failed while sending bct_mem and the boot blob, reporting a USB write timeout.
Therefore, the fault follows the Jetson Orin NX 16GB module across different carrier boards and occurs at a very early boot stage, specifically during SDRAM initialization.
Based on the serial-console evidence and the previous cross-testing, this strongly indicates a module-level hardware failure involving the SDRAM subsystem, memory interface, memory power circuitry, or another related component of the Jetson SoM. It is not consistent with an Ubuntu, NVMe, application, display-output, or operating-system issue.
I have now completed the technical diagnostic procedure requested by NVIDIA. I therefore ask that this case be escalated for warranty replacement or RMA evaluation.
Please confirm:
  • whether the attached log is sufficient to approve the RMA;
  • the RMA reference number;
  • the return shipping instructions;
  • the required packaging procedure;
  • whether NVIDIA will provide a prepaid shipping label;
  • and whether the defective module will be repaired or replaced.
I would also like to reiterate my concern regarding the level of customer-side hardware diagnosis required in this case. I have had to purchase additional equipment, identify and connect to a hardware debug interface, handle the Jetson module and carrier boards, configure UART communications, and perform an RCA procedure that would normally be carried out by a technical support or repair centre.
Although I have been able to complete the process, this should not be assumed to be appropriate for every customer. An inexperienced customer could damage the module, carrier board, connectors, or related components while carrying out these procedures, potentially introducing additional faults during the diagnostic process.
Unless NVIDIA can identify a specific additional non-invasive test that would materially change the diagnosis, I do not consider further customer-side hardware manipulation justified. At this stage, the appropriate next step should be professional evaluation and warranty replacement through the RMA process.
The complete serial-console log is attached as:
putty.log
Thank you for your assistance. I look forward to receiving confirmation of the RMA procedure.
Best regards,
| WayneWWW Moderator
August 27 |
(attachments)
putty.log (1.74 MB)
Want to clarify that. The log we need you to share is the one with your attempt flash the board but not another 182 attempts of cold boot.
Please try to flash the board once and share us
  1. the host side log.
  2. the uart side log.
The host side log is the one that you shared previously and the uart side log is the one you saw right after your attempt to flash the board.
Once we confirm this is something that needs to do RMA, we will ask you to do.
Currnet evidence is not sufficient to say so.
Thank you for clarifying that you require both the host-side log and the UART-side log to be recorded simultaneously during a flashing attempt.
First, I need to correct one point in your previous message. I did not perform 182 separate cold-boot attempts. I performed one continuous UART recording during a single powered session. The Jetson module itself entered an uncontrolled reset loop, repeatedly restarting during MB1 SDRAM initialization.
A genuine flashing attempt has already been performed and fully recorded. I am attaching the complete host-side log from that attempt:
The test was performed on 4 August 2026 using the flashing environment and procedure provided by Yahboom.
The setup was as follows:
  • Jetson Orin NX 16GB module placed in Force Recovery Mode.
  • Module consistently detected by the host as:
  • USB autosuspend disabled.
  • NVMe SSD removed.
  • Original power supply used.
  • Heatsink and fan installed.
  • Direct USB-C connection to the host, without a USB hub.
  • Flashing environment located at:
  • Yahboom-provided command executed:
    sudo ./yahboom_flash.sh.x
  • BSP version:
    L4T R36.4.4
  • Target configuration:
    jetson-orin-nano-devkit-super
The attached complete host-side log shows that the flashing process reached the following stage:
Sending bct_mem
Sending blob
Therefore, this was a real flashing attempt in Force Recovery Mode. The module communicated with the host, was detected as an NVIDIA APX device, and started receiving the flashing payload, but the process failed during the transfer of bct_mem and the boot blob.
At the time this flashing attempt was performed, I did not have a USB-to-UART adapter because NVIDIA had not yet requested a simultaneous UART capture. I purchased the required adapter only after NVIDIA subsequently asked me to provide a serial-console log. Consequently, a simultaneous UART-side log does not exist for the previous flashing attempt.
The separate UART cold-boot log already submitted shows that:
  • QSPI initialization succeeds.
  • MEM-BCT-0 is read successfully.
  • The MEM-BCT header and binary integrity checks succeed.
  • MB1 repeatedly reaches SDRAM initialization.
  • The module resets immediately after PLLM/PLLHUB and memory-encryption configuration.
  • The module never reaches MB2 or UEFI.
The problem has also been reproduced with the module installed on an official NVIDIA P3768 carrier board. In addition, another compatible Jetson module worked correctly on the original Yahboom carrier board. The fault therefore follows the Orin NX 16GB module across different carrier boards.
I understand that you now require one additional flashing attempt with simultaneous host-side and UART-side logging. I am prepared to perform one final synchronized test. However, before carrying out another hardware-level flashing operation, please provide the exact NVIDIA-supported procedure, including:
  1. Which carrier board I must use: the official NVIDIA P3768 carrier or the Yahboom carrier.
  2. The required host operating system and version.
  3. Whether a native Ubuntu installation is mandatory or the Yahboom-provided virtual machine is acceptable.
  4. The exact JetPack and L4T version to use.
  5. The exact board configuration and flashing command.
  6. Whether the NVMe SSD must be installed or removed.
  7. The exact Force Recovery and power-up sequence.
  8. The required order for starting the UART recording, host-side logging and flashing command.
  9. The expected UART configuration.
  10. Confirmation that this will be the final diagnostic test required before the RMA decision.
Please review the attached complete host-side flashing log and provide the precise instructions for the synchronized test.
I have already performed extensive cross-testing, purchased additional diagnostic equipment and reproduced the fault on an official NVIDIA carrier board. I will perform one final controlled test following NVIDIA’s exact procedure, but I do not consider further undefined or trial-and-error hardware manipulation appropriate.
Best regards,
Yahoo Mail: Busca, organiza, conquista
Want to clarify. I feel there are something that is misled here.
  1. What is Yahboom carrier? This sounds not a NV devkit at all. We don’t do a RMA for a custom board directly. You may need to contact the vendor for Yahboom carrier board.
  2. To provide a completed log, you need to share the host side log + UART log that generated at same time. Flash is an process run at host + device at same time. You should not share a host side log generated 5 days ago before the UART log. Those 2 are not paired and not worthy comparing them together.
  3. Please try with rel-36.5 which is the latest version of Jetpack instead of rel-36.4.4 to avoid the PCN update on a SOM.
The most critical point is (1) here. We don’t do a RMA process for a custom board directly. You may need to contact distributors first.
Sorry that I didn’t notice that in the beginning.
Thank you for the clarification. I agree that there has been a misunderstanding, so I would like to clarify the hardware setup precisely.
I am not requesting an RMA for the Yahboom carrier board.
The Yahboom carrier was only the original carrier on which the failure first appeared. The product currently under diagnosis is the NVIDIA Jetson Orin NX 16GB production module itself:
  • NVIDIA Jetson Orin NX 16GB SoM
  • Module ID: P3767-0000
  • NVIDIA P/N: 900-13767-0000-001
Most importantly, the UART cold-boot log I recently submitted was not captured on the Yahboom carrier board.
That log was captured with the problematic NVIDIA Jetson Orin NX 16GB module installed on my official NVIDIA P3768 carrier board, using the J14 debug UART interface.
Therefore, the latest failure was reproduced using:
  • the NVIDIA Jetson Orin NX 16GB production module;
  • an official NVIDIA P3768 carrier board;
  • the official NVIDIA power supply;
  • and the documented J14 UART debug interface.
The Yahboom carrier was not involved in that UART test.
I also understand and accept your clarification that the host-side flashing log and UART-side log must be generated simultaneously during the same flashing attempt. I will therefore perform one new synchronized flashing test.
To eliminate the custom-carrier variable completely, the new test will be performed using:
  • the official NVIDIA P3768 carrier board;
  • the NVIDIA Jetson Orin NX 16GB P3767-0000 module;
  • the official NVIDIA BSP;
  • no Yahboom carrier board;
  • no Yahboom flashing script;
  • simultaneous host-side and UART-side logging.
Before performing the test, please confirm the exact configuration that you want me to use so that the resulting logs are accepted without requiring another repetition:
  1. Should I use exactly Jetson Linux r36.5, or should I use the latest available release in the r36.5.x branch?
  2. Which exact NVIDIA flashing command and board configuration should I use for the P3767-0000 module installed on the P3768 carrier?
  3. Should the NVMe SSD be installed or removed during the test?
  4. Should I flash only the module firmware/QSPI, or should I flash the complete system to NVMe?
  5. Which Ubuntu host version should be used?
  6. Can the host-side log be captured from an Ubuntu virtual machine with direct USB passthrough, or is a native Ubuntu installation mandatory?
  7. Please confirm the required start sequence for:
    • UART logging;
    • Force Recovery Mode;
    • host-side logging;
    • and the flashing command.
Once you confirm these parameters, I will perform one controlled flashing attempt and provide the paired host-side and UART-side logs generated during exactly the same execution.
Regarding the RMA point, I fully understand that NVIDIA does not provide an RMA for a third-party carrier board. Again, I am not requesting an RMA for the Yahboom carrier.
If the synchronized test on the official NVIDIA P3768 carrier confirms that the NVIDIA Jetson Orin NX 16GB SoM is defective, please clarify whether the module RMA would be processed by NVIDIA Customer Care or whether I should submit NVIDIA’s technical diagnosis to the original reseller.
Thank you for helping clarify the procedure.
Best regards,
| WayneWWW Moderator
August 28 |
The most critical point is (1) here. We don’t do a RMA process for a custom board.
rel-36.5.x or rel-36.5 are all fine.
  1. Which exact NVIDIA flashing command and board configuration should I use for the P3767-0000 module installed on the P3768 carrier?
You could refer to the document and see which media you are using and then pick the command you used.
  1. Should the NVMe SSD be installed or removed during the test?
It needs to be there so that full flash would happen.
Flash the whole system include QSPI+NVMe.
For your case, 22.04 covers all the situation.
  1. Can the host-side log be captured from an Ubuntu virtual machine with direct USB passthrough, or is a native Ubuntu installation mandatory?
To avoid any kind of potential problem, please use native Ubuntu.
UART logging;
host-side logging;
Your procedure is mostly correct.
Basically we want to check the UART log right after your flash command starts until host side flash log says flash failed and stop.
