Jetson Orin NX 16GB with Jetson Linux 35.4.1 on the Xavier NX developer kit
Thanks for the answer.
After using p3509-a02+p3767-0000.conf in our customized carrier board, Jetpack 5.1.2 could be successfully installed. But, after booting, can’t connect the USB.
After setting GPIO06(pin #130) as pull-up, USB could be connected.
Couild you please let me know why GPIO06 setting affect to the USB in Orin NX?
This issue is same as Flashing Orin to the Xavier-NX devkit based board - #2 by ted.kim.
Thanks,
Leo
