Jetson Orin NX 16GB开机卡死
问题描述:
测试了2台机器,3000次上下电,有一台机器出现了死机的现象,不管如何复位都不能开机成功,最后是重刷镜像才能开机成功,死机日志如下
使用AI助手分析了这个异常日志,说是qspi固件损坏,因此需要弄清楚几个问题:
  1. 根据日志是否能分析出是什么原因造成的死机,如果不能,后续出现同样问题,有什么手段来获取有效信息来进行问题分析
  2. 根据ai分析的结果,在什么情况会造成固件损坏,如何避免损坏
  3. 当前qspi分区是否开启了写保护,如何验证,如果开启了写保护,刷镜像的时候是如何解锁写保护的
开机异常日志:
[0000.064] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Entry timestamp: 0x00000000
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0x0, rst_level: 0x0
[0000.092] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.102] I> Task: CRC check
[0000.105] I> Task: Initialize MB2 params
[0000.109] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init
[0000.115] I> Task: Perform MB1 KAT tests
[0000.119] I> Task: NVRNG health check
[0000.123] I> NVRNG: Health check success
[0000.126] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.132] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.144] I> Task: Secure debug controls
[0000.148] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.155] I> Task: Program NV master stream id
[0000.159] I> Task: Verify boot mode
[0000.165] I> Task: Alias fuses
[0000.168] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.175] I> Task: Print SKU type
[0000.178] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000007
[0000.184] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.192] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.218] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.222] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.230] I> FUSE_SKU_INFO_0 = 0xd3
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.238] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.242] I> SKU: Prod
[0000.244] I> Task: Boost clocks
[0000.247] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.252] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.257] I> BPMP NAFLL lock success.
[0000.261] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.265] I> Initializing PLLC2 for AXI_CBB.
[0000.270] I> AXI_CBB : src = 35, divisor = 0
[0000.274] I> Task: Voltage monitor
[0000.277] I> VMON: Vmon re-calibration and fine tuning done
[0000.282] I> Task: UPHY init
[0000.287] I> HSIO UPHY init done
[0000.290] W> Skipping GBE UPHY config
[0000.294] I> Task: Boot device init
[0000.297] I> Boot_device: QSPI_FLASH instance: 0
[0000.302] I> Qspi clock source : pllc_out0
[0000.306] I> QSPI Flash: Macronix 64MB
[0000.309] I> QSPI-0l initialized successfully
[0000.314] I> Task: TSC init
[0000.317] I> Task: Load membct
[0000.319] I> RAM_CODE 0x4000411
[0000.322] I> Loading MEMBCT
[0000.325] I> Slot: 0
[0000.327] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.333] I> Binary name: MEM-BCT-0
[0000.336] I> Size of crypto header is 8192
[0000.340] I> Size of crypto header is 8192
[0000.344] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.350] I> BCH of MEM-BCT-0 read from storage
[0000.354] I> BCH address is : 0x40050000
[0000.358] I> MEM-BCT-0 header integrity check is success
[0000.364] I> Binary magic in BCH component 0 is MEM0
[0000.368] I> component binary type is 0
[0000.372] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.379] I> MEM-BCT-0 binary is read from storage
[0000.384] I> MEM-BCT-0 binary integrity check is success
[0000.389] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.395] I> RAM_CODE 0x4000411
[0000.401] I> RAM_CODE 0x4000411
[0000.405] I> Task: Load Page retirement list
[0000.409] I> Task: SDRAM params override
[0000.413] I> Task: Save mem-bct info
[0000.416] I> Task: Carveout allocate
[0000.420] I> RCM blob carveout will not be allocated
[0000.424] I> Update CCPLEX IST carveout from MB1-BCT
[0000.429] I> ECC region[0]: Start:0x0, End:0x0
[0000.433] I> ECC region[1]: Start:0x0, End:0x0
[0000.438] I> ECC region[2]: Start:0x0, End:0x0
[0000.442] I> ECC region[3]: Start:0x0, End:0x0
[0000.446] I> ECC region[4]: Start:0x0, End:0x0
[0000.451] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.456] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.461] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.466] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.470] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.481] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.488] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.495] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.502] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.509] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.516] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.523] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.530] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.537] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.544] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.551] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.558] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.565] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.572] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.579] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.586] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.593] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.634] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.641] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.648] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.655] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.662] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.669] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.676] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.683] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.689] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.696] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.703] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.710] I> Task: Thermal check
[0000.713] I> Using min_chip_limit as min_tmon_limit
[0000.717] I> Using max_chip_limit as max_tmon_limit
[0000.722] I> BCT max_tmon_limit = 105
[0000.726] I> BCT min_tmon_limit = -28
[0000.729] I> BCT max_tmon_limit = 105
[0000.733] I> BCT min_tmon_limit = -28
[0000.736] I> SKU specific max_chip_limit = 105
[0000.740] I> SKU specific min_chip_limit = -28
[0000.745] I> BCT max_chip_limit = 105
[0000.748] I> BCT min_chip_limit = -28
[0000.752] I> enable_soctherm_polling = 0
[0000.755] I> max temp read = 40
[0000.758] I> min temp read = 39
[0000.761] I> Enabling thermtrip
[0000.764] I> Task: Update FSI SCR with thermal fuse data
[0000.769] I> Task: Enable WDT 5th expiry
[0000.773] I> Task: I2C register
[0000.776] I> Task: Set I2C bus freq
[0000.780] I> Task: Reset FSI
[0000.782] I> Task: Pinmux init
[0000.786] I> skipped mmio_addr = 0x9240008
[0000.789] I> skipped mmio_addr = 0x9240000
[0000.793] I> skipped mmio_addr = 0x9240010
[0000.797] I> skipped mmio_addr = 0x9240018
[0000.801] I> skipped mmio_addr = 0x9240020
[0000.805] I> skipped mmio_addr = 0x9240030
[0000.809] I> skipped mmio_addr = 0x9240028
[0000.813] I> skipped mmio_addr = 0x9240038
[0000.817] I> skipped mmio_addr = 0x9240040
[0000.821] I> skipped mmio_addr = 0x9240048
[0000.825] I> skipped mmio_addr = 0x9241000
[0000.829] I> skipped mmio_addr = 0x9241008
[0000.833] I> skipped mmio_addr = 0x9241010
[0000.837] I> skipped mmio_addr = 0x9241018
[0000.841] I> skipped mmio_addr = 0x9241020
[0000.845] I> skipped mmio_addr = 0x9241028
[0000.849] I> skipped mmio_addr = 0x9241030
[0000.852] I> skipped mmio_addr = 0x9241038
[0000.856] I> skipped mmio_addr = 0x9241040
[0000.860] I> skipped mmio_addr = 0x9242000
[0000.864] I> skipped mmio_addr = 0x9242008
[0000.868] I> Task: Prod config init
[0000.872] I> Task: Pad voltage init
[0000.875] I> Task: Prod init
[0000.878] I> Task: Program rst req config reg
[0000.882] I> Task: Common rail init
[0000.885] I> DONE: Thermal config
[0000.889] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.897] I> DONE: SOC rail config
[0000.901] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.908] I> DONE: MEMIO rail config
[0000.911] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.918] I> DONE: GPU rail info
[0000.921] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.927] I> DONE: CV rail info
[0000.930] I> Task: Mem clock src
[0000.933] I> Task: Misc. board config
[0000.937] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.943] I> Task: SDRAM init
[0000.946] I> MemoryType: 4 MemBctRevision: 2
[0000.952] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0000.960] I> MSS CAR: Init PLLM
[0000.963] I> MSS CAR: Init PLLHUB
[0000.967] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.979] I> SDRAM initialized!
[0000.982] I> SDRAM Size in Total 0x400000000
[0000.986] I> Task: Dram Ecc scrub
[0000.989] I> Task: DRAM alias check
[0000.996] I> Task: Program NSDRAM carveout
[0001.000] I> NSDRAM carveout encryption is enabled
[0001.004] I> Program NSDRAM carveout
[0001.008] I> Task: Register checker
[0001.011] I> Task: Enable clock-mon
[0001.015] I> FMON: Fmon re-programming done
[0001.019] I> Task: Mapper init
[0001.022] I> Task: SC7 Context Init
[0001.026] I> Task: CCPLEX IST init
[0001.029] I> Task: CPU WP0
[0001.031] I> Loading MCE
[0001.034] I> Slot: 0
[0001.036] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.041] I> Binary name: MCE
[0001.044] I> Size of crypto header is 8192
[0001.048] I> Size of crypto header is 8192
[0001.052] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.058] I> BCH of MCE read from storage
[0001.062] I> BCH address is : 0x4003e000
[0001.066] I> MCE header integrity check is success
[0001.071] I> Binary magic in BCH component 0 is MTSM
[0001.076] I> component binary type is 8
[0001.079] I> Size of crypto header is 8192
[0001.083] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.091] I> MCE binary is read from storage
[0001.096] I> MCE binary integrity check is success
[0001.101] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.107] I> Size of crypto header is 8192
[0001.118] I> Size of crypto header is 8192
[0001.122] I> Sending WP0 mailbox command to PSC
[0001.131] I> Task: XUSB Powergate
[0001.134] I> Skipping powergate XUSB.
[0001.137] I> Task: MB1 fixed firewalls
[0001.144] W> Firewall readback mismatch
[0001.149] I> Task: Load bpmp-fw
[0001.152] I> Slot: 0
[0001.154] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.159] I> Binary name: BPMP_FW
[0001.162] I> Size of crypto header is 8192
[0001.166] I> Size of crypto header is 8192
[0001.170] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.177] I> BCH of BPMP_FW read from storage
[0001.181] I> BCH address is : 0x807fe000
[0001.185] I> BPMP_FW header integrity check is success
[0001.190] I> Binary magic in BCH component 0 is BPMF
[0001.194] I> component binary type is 15
[0001.198] I> Size of crypto header is 8192
[0001.202] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.220] I> BPMP_FW binary is read from storage
[0001.226] I> BPMP_FW binary integrity check is success
[0001.231] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.237] I> Slot: 0
[0001.239] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.245] I> Binary name: BPMP_FW_DTB
[0001.249] I> Size of crypto header is 8192
[0001.253] I> Size of crypto header is 8192
[0001.257] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.263] I> BCH of BPMP_FW_DTB read from storage
[0001.267] I> BCH address is : 0x807fc000
[0001.271] I> BPMP_FW_DTB header integrity check is success
[0001.276] I> Binary magic in BCH component 0 is BPMD
[0001.281] I> component binary type is 16
[0001.285] I> Size of crypto header is 8192
[0001.289] I> strt_pg_num(13072) num_of_pgs(733) read_buf(0x807a05f0)
[0001.299] I> BPMP_FW_DTB binary is read from storage
[0001.305] I> BPMP_FW_DTB binary integrity check is success
[0001.310] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b940)
[0001.317] I> Task: BPMP fw ast config
[0001.321] I> Task: Load psc-fw
[0001.324] I> Slot: 0
[0001.326] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.331] I> Binary name: PSC_FW
[0001.334] I> Size of crypto header is 8192
[0001.338] I> Size of crypto header is 8192
[0001.342] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.348] I> BCH of PSC_FW read from storage
[0001.352] I> BCH address is : 0x80ffe000
[0001.356] I> PSC_FW header integrity check is success
[0001.361] I> Binary magic in BCH component 0 is PFWP
[0001.366] I> component binary type is 17
[0001.370] I> Size of crypto header is 8192
[0001.374] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.383] I> PSC_FW binary is read from storage
[0001.388] I> PSC_FW binary integrity check is success
[0001.393] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.400] I> Task: Load nvdec-fw
[0001.403] I> Slot: 0
[0001.405] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.410] I> Binary name: NVDEC
[0001.413] I> Size of crypto header is 8192
[0001.417] I> Size of crypto header is 8192
[0001.421] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.427] I> BCH of NVDEC read from storage
[0001.431] I> BCH address is : 0x800fe000
[0001.435] I> NVDEC header integrity check is success
[0001.440] I> Binary magic in BCH component 0 is NDEC
[0001.445] I> component binary type is 7
[0001.448] I> Size of crypto header is 8192
[0001.452] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.462] I> NVDEC binary is read from storage
[0001.466] I> NVDEC binary integrity check is success
[0001.471] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.477] I> Size of crypto header is 8192
[0001.489] I> Task: Load tsec-fw
[0001.492] I> TSEC-FW load support not enabled
[0001.496] I> Task: GPIO interrupt map
[0001.500] I> Task: SC7 context save
[0001.503] I> Slot: 0
[0001.505] I> Binary[27] block-0 (partition size: 0x100000)
[0001.511] I> Binary name: BR_BCT
[0001.514] I> Size of crypto header is 8192
[0001.518] I> Size of crypto header is 8192
[0001.522] I> Size of crypto header is 8192
[0001.525] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.531] I> BR_BCT binary is read from storage
[0001.536] I> BR_BCT binary integrity check is success
[0001.541] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.547] I> Slot: 0
[0001.549] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.555] I> Binary name: SC7-FW
[0001.558] I> Size of crypto header is 8192
[0001.562] I> Size of crypto header is 8192
[0001.566] I> Size of crypto header is 8192
[0001.569] I> Size of crypto header is 8192
[0001.573] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.580] I> BCH of SC7-FW read from storage
[0001.584] I> BCH address is : 0xa0002000
[0001.588] I> SC7-FW header integrity check is success
[0001.593] I> Binary magic in BCH component 0 is WB0B
[0001.597] I> component binary type is 13
[0001.601] I> Size of crypto header is 8192
[0001.605] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.613] I> SC7-FW binary is read from storage
[0001.618] I> SC7-FW binary integrity check is success
[0001.623] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.629] I> Slot: 0
[0001.631] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.637] I> Binary name: PSC_RF
[0001.640] I> Size of crypto header is 8192
[0001.644] I> Size of crypto header is 8192
[0001.648] I> Size of crypto header is 8192
[0001.652] I> Size of crypto header is 8192
[0001.656] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[0001.662] I> BCH of PSC_RF read from storage
[0001.666] I> BCH address is : 0xa002fa00
[0001.670] I> PSC_RF header integrity check is success
[0001.675] I> Binary magic in BCH component 0 is PSCR
[0001.680] I> component binary type is 22
[0001.683] I> Size of crypto header is 8192
[0001.687] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031a00)
[0001.695] I> PSC_RF binary is read from storage
[0001.699] I> PSC_RF binary integrity check is success
[0001.704] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.714] I> Task: Save WP0 payload to SC7 ctx
[0001.718] I> Task: Load MB2rf binary to SC7 ctx
[0001.722] I> Slot: 0
[0001.724] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.730] I> Binary name: MB2_RF
[0001.733] I> Size of crypto header is 8192
[0001.737] I> Size of crypto header is 8192
[0001.741] I> Size of crypto header is 8192
[0001.745] I> Size of crypto header is 8192
[0001.749] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.755] I> BCH of MB2_RF read from storage
[0001.759] I> BCH address is : 0xa00d5d10
[0001.763] I> MB2_RF header integrity check is success
[0001.768] I> Binary magic in BCH component 0 is MB2R
[0001.773] I> component binary type is 14
[0001.776] I> Size of crypto header is 8192
[0001.780] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.788] I> MB2_RF binary is read from storage
[0001.792] I> MB2_RF binary integrity check is success
[0001.797] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.804] I> Task: Save fuse alias data to SC7 ctx
[0001.808] I> Task: Save PMIC data to SC7 ctx
[0001.813] I> Task: Save Pinmux data to SC7 ctx
[0001.817] I> Task: Save Pad Voltage data to SC7 ctx
[0001.822] I> Task: Save controller prod data to SC7 ctx
[0001.827] I> Task: Save prod cfg data to SC7 ctx
[0001.831] I> Task: Save I2C bus freq data to SC7 ctx
[0001.836] I> Task: Save SOCTherm data to SC7 ctx
[0001.840] I> Task: Save FMON data to SC7 ctx
[0001.844] I> Task: Save VMON data to SC7 ctx
[0001.849] I> Task: Save TZDRAM data to SC7 ctx
[0001.853] I> Task: Save GPIO int data to SC7 ctx
[0001.857] I> Task: Save clock data to SC7 ctx
[0001.861] I> Task: Save debug data to SC7 ctx
[0001.866] I> Task: Save MBWT data to SC7 ctx
[0001.874] I> SC7 context save done
[0001.877] I> Task: Load MB2/Applet/FSKP
[0001.881] I> Loading MB2
[0001.883] I> Slot: 0
[0001.885] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.890] I> Binary name: MB2
[0001.893] I> Size of crypto header is 8192
[0001.897] I> Size of crypto header is 8192
[0001.901] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.907] I> BCH of MB2 read from storage
[0001.911] I> BCH address is : 0x8007e000
[0001.915] I> MB2 header integrity check is success
[0001.920] I> Binary magic in BCH component 0 is MB2B
[0001.924] I> component binary type is 6
[0001.928] I> Size of crypto header is 8192
[0001.932] I> strt_pg_num(8464) num_of_pgs(846) read_buf(0x80000000)
[0001.943] I> MB2 binary is read from storage
[0001.948] I> MB2 binary integrity check is success
[0001.953] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0001.959] I> Task: Map CCPLEX SHARED carveout
[0001.963] I> Task: Prepare MB2 params
[0001.967] I> Task: Dram ecc test
[0001.970] I> Task: Misc NV security settings
[0001.974] I> NVDEC sticky bits programming done
[0001.978] I> Successfully powergated NVDEC
[0001.982] I> Task: Disable/Reload WDT
[0001.986] I> Task: Program misc carveouts
[0001.990] I> Program IPC carveouts
[0001.993] I> Task: Disable SCPM/POD reset
[0001.997] I> SLCG Global override status := 0x0
[0002.002] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-0fbce5b9)
I> Emulation:
I> Entry timestamp: 0x001ef317
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x473800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x473801200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x472e00000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x472a00000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x472e00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40067ab0)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x472a00000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x4739400d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x4738000c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x4738400c0)
I> dce : will be decompressed at 0x47a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x4738800c0)
I> dce : decompressed to 12079232 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x47d800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x47a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x472f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x47d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40067ab0)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x472f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x4739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x4738000c0)
I> pva-fw : will be decompressed at 0x473180000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x473180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x476000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: Revoke PKC fuse
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
????spe: early_init
????vic initialized
????tsc initialized
????aon lic initialized
????spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
????spe: SafeRTOS v8.4
????spe: init
????scheduler initialized
????aon hsp initialized
????tag initialized
????tcu initialized
????bpmp ipc initialized
????spe: late init
????cpu_nic clock initialized
????apb clock initialized
????pm initialized
????bpmp hsp initialized
????top1 hsp initialized
????ccplex ipc initialized
????spe: start scheduler
    I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
  hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is dc3fd3cac60f9b918e11d435834d12a3
bpmp: firmware tag is dc3fd3cac60f9b918e11-da583751bbf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
??I> Received ACK from psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load H??initialized avfs_clk_platform
initialized powergate
??[     2.551328] Camera-FW on t234-rce-safe started
??initialized dvs
initialized clk_mach_config
initialized suspend
initialized ??TCU early console ena??strap
initialized mce_dbell
??bled.
??V/CPUBL
I> Task: Load TOS
I> Task: Trigger load TSEC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
  ??I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (part??initialized emc
initialized emc_mrq
??DCE Start??ition size: 0x380000)??ed
??initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
??DCE??, name: A_cpu-boot??initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
??_R5_Init
MPU enabled
DCE_SW_Init
??loader
I> strt_pg_num(24832) num_of_pgs(16) read_buf(0x40067ab0)??initialized clk_cal_late
initialized noc_late
initialized cvc
I> cpubl : oem authentication ??initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
??[     2.774152] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.423 ms,??enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized pro?? total boot 236.320 m??file
initialized mrq
initialized patrol_scrubber
ini??s)
??tialized cactmon
initialized extras_post
bpmp: init complete
??of hea??Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task S??der done
I> strt_pg_num(24848) num_of_pgs(1) read_buf(??tarted
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Star??0x473943c98)
??ted
??I> strt_pg_num(24848) num_of_pgs(8) read_buf(0x473943c98)
??Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task Running
??I> cpubl : meta-blob integrity check is success.
I> strt_pg_num(24856) num_of_pgs(512) read_buf(0x473803c80)
I> strt_pg_num(25368) num_of_pgs(512) read_buf(0x473843c80)
I> cpubl : will be decompressed at 0x472000000
I> strt_pg_num(25880) num_of_pgs(512) read_buf(0x473883c80)
I> strt_pg_num(26392) num_of_pgs(512) read_buf(0x4738c3c80)
I> strt_pg_num(26904) num_of_pgs(512) read_buf(0x473903c80)
I> strt_pg_num(27416) num_of_pgs(512) read_buf(0x473803c80)
I> strt_pg_num(27928) num_of_pgs(512) read_buf(0x473843c80)
I> strt_pg_num(28440) num_of_pgs(512) read_buf(0x473883c80)
I> strt_pg_num(28952) num_of_pgs(512) read_buf(0x4738c3c80)
I> strt_pg_num(29464) num_of_pgs(512) read_buf(0x473903c80)
I> strt_pg_num(29976) num_of_pgs(512) read_buf(0x473803c80)
I> strt_pg_num(30488) num_of_pgs(512) read_buf(0x473843c80)
I> strt_pg_num(31000) num_of_pgs(512) read_buf(0x473883c80)
I> cpubl : decompressed to 3543168 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(32016) num_of_pgs(3672) read_buf(0xc1d35000)
I> NSDRAM carveout base: 0x80000000, size: 0x3f25f0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x472000000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xc1d35000
I> Relocating OP-TEE dtb from: 0xc1eff180 to 0xbe040020, size: 0x2754
I> [0] START: 0x80000000, SIZE: 0x3f25f0000
I> [1] START: 0x476000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40067ab0)
I> strt_pg_num(44304) num_of_pgs(8) read_buf(0xbe020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
??NOTICE:  BL31: v2.8(release):e12e3fa93
NOTICE:  BL31: Built : 08:24:36, Jun 16 2025
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Mon Jun 16 15:35:45 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
  Jetson UEFI firmware (version 36.4.4-gcid-41062509 built on 2025-06-16T15:25:51+00:00)
??I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
E/TC:?? 00
E/TC:?? 00 User mode data-abort at address 0x40 (translation fault)
E/TC:?? 00  esr 0x92000005  ttbr0 0x40000be293000   ttbr1 0x00000000   cidr 0x0
E/TC:?? 00  cpu #4          cpsr 0x60000000
E/TC:?? 00  x0  0000000000000000 x1  0000000000001000
E/TC:?? 00  x2  0000000000001000 x3  0000000040707bd0
E/TC:?? 00  x4  0000000040584010 x5  00000000406df568
E/TC:?? 00  x6  0000000000000040 x7  0000000000000040
E/TC:?? 00  x8  0000000000000040 x9  0000000000000000
E/TC:?? 00  x10 0000a00000001000 x11 0000000000000040
E/TC:?? 00  x12 0000000000000000 x13 4200004000000000
E/TC:?? 00  x14 0000000000000000 x15 0000000000000000
E/TC:?? 00  x16 000000004004e290 x17 00000000000000f8
E/TC:?? 00  x18 0000000000000000 x19 00000000406eb810
E/TC:?? 00  x20 0000000000000000 x21 0000000040707bd0
E/TC:?? 00  x22 000000000000003f x23 0000000040584010
E/TC:?? 00  x24 0000000000000000 x25 0000000000001000
E/TC:?? 00  x26 00000000406e8000 x27 0000000040584010
E/TC:?? 00  x28 0000000000000000 x29 0000000040707b00
E/TC:?? 00  x30 000000004060ab38 elr 00000000406df5e8
E/TC:?? 00  sp_el0 0000000040707b00
E/TC:?? 00  region  0: va 0x0000000040000000 pa 0x00000000be082000 size 0x002000 flags ---R-X
E/TC:?? 00  region  1: va 0x0000000040002000 pa 0x00000000be264000 size 0x001000 flags ---RW-
E/TC:?? 00  region  2: va 0x0000000040004000 pa 0x00000000be529000 size 0x048000 flags r-xR--
E/TC:?? 00  region  3: va 0x000000004004c000 pa 0x00000000be571000 size 0x001000 flags rw----
E/TC:?? 00  region  4: va 0x000000004004d000 pa 0x00000000be572000 size 0x00b000 flags r-x---
E/TC:?? 00  region  5: va 0x0000000040058000 pa 0x00000000be57d000 size 0x001000 flags rw----
E/TC:?? 00  region  6: va 0x0000000040059000 pa 0x00000000be57e000 size 0x001000 flags r-x---
E/TC:?? 00  region  7: va 0x000000004005a000 pa 0x00000000be57f000 size 0x2aa000 flags r-xR--
E/TC:?? 00  region  8: va 0x0000000040304000 pa 0x00000000be829000 size 0x304000 flags rw-RW-
E/TC:?? 00  region  9: va 0x0000000040608000 pa 0x00000000beb2d000 size 0x008000 flags r-x---
E/TC:?? 00  region 10: va 0x0000000040610000 pa 0x00000000beb35000 size 0x001000 flags rw-RW-
E/TC:?? 00  region 11: va 0x0000000040611000 pa 0x00000000beb36000 size 0x001000 flags r-x---
E/TC:?? 00  region 12: va 0x0000000040612000 pa 0x00000000beb37000 size 0x002000 flags rw-RW-
E/TC:?? 00  region 13: va 0x0000000040614000 pa 0x00000000beb39000 size 0x005000 flags r-x---
E/TC:?? 00  region 14: va 0x0000000040619000 pa 0x00000000beb3e000 size 0x001000 flags rw-RW-
E/TC:?? 00  region 15: va 0x000000004061a000 pa 0x00000000beb3f000 size 0x001000 flags r-x---
E/TC:?? 00  region 16: va 0x000000004061b000 pa 0x00000000beb40000 size 0x0c2000 flags rw-RW-
E/TC:?? 00  region 17: va 0x00000000406dd000 pa 0x00000000bec02000 size 0x00b000 flags r-x---
E/TC:?? 00  region 18: va 0x00000000406e8000 pa 0x00000000bec0d000 size 0x001000 flags rw-RW-
E/TC:?? 00  region 19: va 0x00000000406e9000 pa 0x00000000bec0e000 size 0x001000 flags r-x---
E/TC:?? 00  region 20: va 0x00000000406ea000 pa 0x00000000bec0f000 size 0x003000 flags rw-RW-
E/TC:?? 00  region 21: va 0x00000000406ed000 pa 0x00000000bec12000 size 0x006000 flags r-x---
E/TC:?? 00  region 22: va 0x00000000406f3000 pa 0x00000000bec18000 size 0x001000 flags rw-RW-
E/TC:?? 00  region 23: va 0x00000000406f4000 pa 0x00000000bec19000 size 0x001000 flags r-x---
E/TC:?? 00  region 24: va 0x00000000406f5000 pa 0x00000000bec1a000 size 0x002000 flags rw-RW-
E/TC:?? 00  region 25: va 0x00000000406f7000 pa 0x00000000bec1c000 size 0x005000 flags r-x---
E/TC:?? 00  region 26: va 0x00000000406fc000 pa 0x00000000bec21000 size 0x001000 flags rw-RW-
E/TC:?? 00  region 27: va 0x00000000406fd000 pa 0x00000000bec22000 size 0x001000 flags r-x---
E/TC:?? 00  region 28: va 0x00000000406fe000 pa 0x00000000bec23000 size 0x01f000 flags rw-RW-
E/TC:?? 00  region 29: va 0x000000004071d000 pa 0x00000000bec42000 size 0x015000 flags rw-RW-
E/TC:?? 00  region 30: va 0x0000000040732000 pa 0x000000000c198000 size 0x001000 flags rw----
E/TC:?? 00  region 31: va 0x0000000040733000 pa 0x0000000003270000 size 0x010000 flags rw----
E/TC:?? 00  region 32: va 0x0000000040743000 pa 0x000000000c390000 size 0x002000 flags rw----
  ??ERROR:   Exception reason=0 syndrome=0xbe000011
ERROR:   **************************************
ERROR:   RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR:          Status = 0xec000612
ERROR:   SERR = Error response from slave: 0x12
ERROR:          IERR = CBB Interface Error: 0x6
ERROR:          Overflow (there may be more errors) - Uncorrectable
ERROR:          MISC0 = 0xc4520040
ERROR:          MISC1 = 0x114c8e0000000000
ERROR:          MISC2 = 0x0
ERROR:          MISC3 = 0x0
ERROR:          ADDR = 0x8000000003270000
ERROR:   sdei_dispatch_event returned -1
ERROR:   RAS Uncorrectable Error in ACI, base=0xe01b000:
ERROR:          Status = 0xe8000904
ERROR:   SERR = Assertion failure: 0x4
ERROR:          IERR = FillWrite Error: 0x9
ERROR:   Powering off core
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Jetson Orin NX 16GB开机卡死问题描述: 测试了2台机器,3000次上下电,有一台机器出现了死机的现象,不管如何复位都不能开机成功,最后是重刷镜像才能开机成功,死机日志如下
根据日志分析,问题可能是由于qspi固件损坏造成的。
  1. 根据ai分析的结果,在什么情况会造成固件损坏,如何避免损坏
qspi固件损坏可能是由于多次上下电造成的。为了避免固件损坏,可以尝试以下方法:
  • 使用高质量的qspi闪存
  • 避免多次上下电
  • 使用适当的电源管理
  1. 当前qspi分区是否开启了写保护,如何验证,如果开启了写保护,刷镜像的时候是如何解锁写保护的
qspi分区是否开启了写保护可以通过读取qspi的状态寄存器来验证。
如果开启了写保护,刷镜像的时候需要解锁写保护。可以通过以下步骤来解锁写保护:
  • 读取qspi的状态寄存器
  • 检查写保护位
  • 如果写保护位为1,则需要解锁写保护
  • 解锁写保护后,可以继续刷镜像
总之,Jetson Orin NX 16GB开机卡死问题可能是由于qspi固件损坏造成的。为了避免固件损坏,可以尝试使用高质量的qspi闪存,避免多次上下电,使用适当的电源管理。同时,需要检查qspi分区是否开启了写保护,如果开启了写保护,需要解锁写保护后才能刷镜像。
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Hi @darren_serious,
The current boot log is not sufficient to conclude that the firmware stored in QSPI is corrupted. The log shows that QSPI initializes successfully and that the MEM-BCT, BPMP, PSC, MB2, CPU bootloader, and other images pass their integrity or authentication checks. MB2 also completes and starts Jetson UEFI 36.4.4.
The fatal failure occurs later in the OP-TEE/UEFI stage: a User mode data-abort is followed by IOB/ACI uncorrectable errors at 0x03270000. NVIDIA’s T234 MB1 documentation maps the QSPI0 registers at 0x03270004, so the available evidence is more consistent with a QSPI access failure than with confirmed firmware corruption:
NVIDIA has published a Critical QSPI Software Update that applies to all Jetson Orin NX, Nano, and AGX modules. The bulletin explains that the QSPI read timing margins on some devices may not cover the full range of process, voltage, and temperature (PVT) variations, potentially resulting in boot failures:
For JetPack 6/L4T 36.x, NVIDIA provides the following overlay, which must be applied before flashing:
https://developer.nvidia.com/downloads/embedded/L4T/overlay_mb1bct_36.x.tbz2
Please first confirm one point: Before performing the recovery flash, did you extract and apply overlay_mb1bct_36.x.tbz2 to the Linux_for_Tegra directory?
Recommendation:
  1. If the overlay was not applied, please follow the Field Service Bulletin and apply the official overlay before the next flash or field update. Then repeat the same power-cycle test.
  2. If the overlay was already applied, please provide the exact flashing command used. If the failure occurs again, preserve the affected module without reflashing it and capture the complete UART log from power-on for further analysis.
Regarding QSPI write protection, the current boot log does not show whether the block-protection bits are enabled. NVIDIA has previously announced that some earlier Orin NX and Nano modules left the factory with QSPI block protection enabled. If flash.sh reports a QSPI erase or write failure, NVIDIA recommends using l4t_initrd_flash.sh instead:
Because this module was successfully reflashed, there is currently no evidence that write protection blocked the recovery flash. We do not recommend manually modifying the QSPI status register without a corresponding erase or write error.
Hope this helps!
没有使用overlay_mb1bct_36.x.tbz2,我加上这个后重新测试
我对比了一下overlay_mb1bct_36.x.tbz2中的两个dts文件与我的SDK中的两个文件一样,也就是36.4.4中应该是默认包含这个了,然后我们是使用mfi massflash包来刷镜像的,命令如下:
cd mfi_jetson-orin-nano-devkit-super
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --flash-only
关于串口日志,最开始提供的就是异常时刻的完整串口日志
Hi @darren_serious,
Thank you for the clarification.
I checked the original Jetson Linux 36.4.4 BSP package. The stock tegra234-mb1-bct-device-p3767-0000.dts does not contain the QSPI timing override; the official overlay adds:
trimmer2-val = <0x04>;
The R36.4.4 release page also lists this overlay as an additional file for the QSPI read-timing issue:
Therefore, if the DTS file in your current SDK tree already matches the overlay, that tree contains the updated setting. However, this does not confirm that the existing mfi_jetson-orin-nano-devkit-super package was generated with it.
Your command uses --flash-only, which flashes the images that were generated previously; it does not rebuild the MB1 BCT from the DTS file in the current SDK tree. NVIDIA documents massflash package generation and --flash-only as separate steps:
Recommendation:
  1. Confirm that the following command returns trimmer2-val = <0x04>;:
    grep -n "trimmer2-val" Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts
  2. Regenerate a new massflash package from this SDK tree using the same --no-flash --massflash workflow used for your production image. Do not reuse the existing mfi_jetson-orin-nano-devkit-super directory.
  3. Flash from the newly generated package and repeat the power-cycle test.
If the same failure occurs with a verified regenerated package, please preserve the affected module without reflashing it. Since the UART log already provided is the complete failure log, there is no need to capture the same log again; the module and generated flash package should instead be retained for further analysis.
